October 11th, 2010 09:32 PM #1
Fix: Error code 0x8007000D when trying to activate Windows 7
If when you try to activate your copy of Windows 7 or Windows Server 2008, you get an error message: The data is invalid. Error code 8007000d, then you may want to apply this Fix it solution.
msfixit Fix: Error code 0x8007000D when trying to activate Windows 7
This error can even be encountered if you run slsmgr -dlv or slmgr -ato from a command line.
The System account by default has Full Control permissions to the registry path-
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root and any subkeys.
If those permissions have been altered for the ‘Root’ key or any subkey(s), we would see the error code 0x8007000D.
Download Microsoft Fix it 50485 from KB2230957. https://support.microsoft.com/kb/2230957/
Question about the EnableBlurBehind Reg code in Windows 10 TH2
By Nimbi in forum General Windows 10 CustomizationReplies: 2Last Post: January 10th, 2016, 06:28 AM -
Windows 10 wont activate after fresh install
By freak69ize in forum Chill Out RoomReplies: 12Last Post: August 10th, 2015, 06:58 PM -
Repair Corrupted Contacts Cache in WLM 2011: Error Code 8007
By razorsedge in forum General TutorialsReplies: 0Last Post: April 29th, 2011, 08:56 PM -
Troubleshoot Volume Activation error codes and error message
By razorsedge in forum News & ReviewsReplies: 0Last Post: March 1st, 2011, 06:29 AM -
Fix: Unable to boot the System with error code 0×490, with W
By razorsedge in forum News & ReviewsReplies: 0Last Post: March 1st, 2011, 06:09 AM
