Thread: SMART Utility
November 8th, 2010 12:55 AM #1
SMART Utility
Most of the Windows users don’t know about Services. A service is a program or process that run the background and provides support to other programs. Many advanced users disable unused services to speedup Windows. If you are novice user, here is a smart tool to fine tune services in Windows 7.
Attachment 38405
It can simply be downloaded and used as a portable application to customize your Windows services settings, to meet your requirements. With judicious tweaking, it can make your system faster, as you will be disabling services which you do not require.
Tweaking a system has to be done carefully, and more so in the cases of Services. A Windows service is a long running executable that performs specific functions and which is designed not to require user intervention. Windows services can be configured to start when the operating system is booted and run in the background as long as Windows is running, or they can be started manually when required.
You can always tweak your services manually individually, but what this utility does is automate the entire process to give you the desired settings. Based on the recommendations of the BlackVipers Service Configuration Guide, the utility offers 3 sets of pre- configured tweaks :
1. Safe
2. Tweaked
3. Advanced or BareBones
The utility has set the Presets to check for Service before applying Tweak. There is also a button to re-set services to Windows Default Settings.
Quick Rundown of Operations:
1. Click a Service to get additional information about it.
2. Double-Click a Service to Automatically Start or Stop it.
3. Right-Click a Service to View and set StartUp Options (Automatic, Manual & Disabled).
4. Select a Service and Click Open File Location to Locate Service Executable (Does not work on svchost, so if you happen to click a svchost and it opens up your Documents Folder, don’t be alarmed.).
5. Click Refresh To reload the list of Services.
6. Click a preset (Default, Safe, Tweaked, Advanced/BareBones), to set preconfigured Tweaks.
7. The Safe setting is (you guessed it!) safe! Tweak and Advanced settings, are for Advanced users to set their Services.
What is the best utility to get 3r party themes to work?
By Lassar in forum General Windows 10 CustomizationReplies: 3Last Post: February 6th, 2017, 06:41 PM -
FixWin Utility 1.2
By razorsedge in forum Windows tweaking and Management AppsReplies: 1Last Post: April 20th, 2011, 07:10 AM -
Scientific and Technical Documentation Utility
By razorsedge in forum UtilitiesReplies: 0Last Post: September 16th, 2010, 09:52 PM -
ERUNT - The Emergency Recovery Utility NT
By razorsedge in forum Backup and RecoverReplies: 0Last Post: August 8th, 2010, 06:23 AM -
Smart Utility
By mauam in forum MiscellaneousReplies: 7Last Post: June 18th, 2010, 06:31 PM
Lyra Workstation by Niivu Windows 11 22H2+ A new suite based on LYRA'15 by novoo and their setup inspired by the work of imrik
