January 16th, 2011 09:26 PM #1
How to control and reduce the number of Dump Files Windows c
Every time your Windows computer crashes, it creates a Dump File. These mini dump files are memory images of that point in time, when your Windows computer had crashed.
This dump file type includes the following information:
* The Stop message and its parameters and other data
* A list of loaded drivers
* The processor context (PRCB) for the processor that stopped
* The process information and kernel context (EPROCESS) for the process that stopped
* The process information and kernel context (ETHREAD) for the thread that stopped
* The Kernel-mode call stack for the thread that stopped.
Windows 7, by default creates and stores 50 mini dump files. These mini dump files are located in the %SystemRoot%\Minidump directory.
If you are a geek who needs to use these dump files to troubleshoot your computer crashes, then having the last 50 dump files may be of use to you!
If not, they will simply end up eating disk space.
You can if you wish, reduce the number of dump files which your Windows creates.
To do so open regedit and navigate to the following key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CrashControl
Double click MiniDumpsCount and change its value data.
[attachment=0:ngc2pfy5]reduce-mini-dump-600x365.jpg[/attachment:ngc2pfy5]
The default in Windows 7 is 32 Hexadecimal or 50 Decimal. Reduce its Decimal value to 10, if you only want the last 10 mini dump files to be saved.
Pin Control Panel To Taskbar To Quickly Access Control Panel In Windows 8
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 03:44 AM -
How To Reduce Start Screen Size In Windows 8
By razorsedge in forum Tips and TricksReplies: 0Last Post: December 8th, 2012, 02:05 AM -
How to restrict the number of Login attempts in Windows 7
By razorsedge in forum News & ReviewsReplies: 0Last Post: March 25th, 2011, 03:25 PM -
Physical Memory Limits in Crash Dump files for Windows 7
By razorsedge in forum News & ReviewsReplies: 0Last Post: March 7th, 2011, 08:58 PM -
How to reduce the top glass windows borders
By The gimp in forum Windows and caption buttonsReplies: 1Last Post: March 14th, 2010, 11:01 AM
Aegis Windows 11 Port...
