January 21st, 2011 11:11 PM #1
[FIX] Windows 7 Taskbar Resets to Default Settings
[FIX] Windows 7 Taskbar Resets to Default Settings If “Automatically Log On” Feature is Enabled
Some of Windows 7 and Server 2008 R2 users are facing a weird issue now-a-days. When they log off or restart their Windows 7 computers, Taskbar resets to default settings and forgets all their customized settings.
According to Microsoft KB979155 article, it happens because of a race condition between Windows Explorer and Taskhost.exe.
This issue only occurs when "Automatically Log On" feature is enabled. Some people enable this feature to automatic log on to their systems without the need of entering password at login time.
If you are also facing this issue, you can ask Microsoft Support for a hotfix. Its not available for all users, so you'll need to ask them for it.
Or you can follow these simple steps to disable "Automatically Log On" feature which will also fix this issue:
Method 1: Using "User Accounts" Applet
1. Type control userpasswords2 or netplwiz in RUN or Startmenu Searchbox and press Enter. It'll open "User Accounts" window.
2. Now enable "Users must enter a user name and password to use this computer." option.
[attachment=1:1w63wxym]Automatic_Logon_Windows_7.png[/attachment:1w63wxym]
3. Click on Apply button and it'll fix your problem.
Method 2: Using "Registry Editor"
1. Type regedit in RUN or Startmenu Searchbox and press Enter. It'll open "Registry Editor".
2. Now go to following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
3. In right-side pane, change value of AutoAdminLogon to 0 or simply delete it.
[attachment=0:1w63wxym]AutoAdminLogon.png[/attachment:1w63wxym]
4. That's it. Restart your system and it'll fix the problem.
PS: If you are not familiar with Registry editing and want a ready-made script to do the task automatically, download following zip file, extract it and run extracted REG file. It'll fix the problem for you:
[dl:1w63wxym]https://www.mediafire.com/?2187s8gc4iop9q1[/dl:1w63wxym]
StartAllBack Date/Time on taskbar and default app color Win 11
By rom4ster in forum Start MenuReplies: 0Last Post: May 12th, 2022, 05:37 AM -
Startisback taskbar changes back to default after gaming
By Hunk_4TH in forum General Windows 10 CustomizationReplies: 4Last Post: April 6th, 2018, 06:47 PM -
Windows 10 rs1 lock screen won't disable and titlebar color resets
By Wolfy in forum Windows 10 Theme Help and SupportReplies: 30Last Post: October 16th, 2016, 04:57 AM -
how to reset your photoshop to default settings
By _Deano_ in forum General TutorialsReplies: 0Last Post: August 25th, 2010, 08:36 AM -
Default Win7 Theme with Mr. Grims Dark Ultimate Taskbar
By vernon092487 in forum Theme RequestsReplies: 9Last Post: July 12th, 2010, 08:51 AM
Lyra Workstation by Niivu Windows 11 22H2+ A new suite based on LYRA'15 by novoo and their setup inspired by the work of imrik
