February 10th, 2011 07:13 PM #1
How do Disable the annoying Windows 7 startup repair
This has bothered me for quite some time with Windows 7 initiating the startup repair option when I know my OS is in good working order. Most times it is because my machine is overclocked and Esata devices and such are plugged in during shutdown. Even after enabling AHCI in the bios was still getting the startup repair option from time to time so in order to disable just follow these instructions:
Open command prompt and enter the following command
bcdedit /set {default} bootstatuspolicy ignoreallfailures
To restore the startup option, run below command
bcdedit /set {default} bootstatuspolicy displayallfailures
Note: if you had enabled UAC then run the cmd as administrator
Thanks to my friend Ben
Startup Sound Changer is the easiest way to change the startup sound in Windows 7
By hb860 in forum Windows 7 Customization ToolsReplies: 2Last Post: November 23rd, 2013, 01:33 PM -
How To Enable/Disable Fast Startup In Windows 8
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 03:37 AM -
Windows 7 In Place Upgrade Repair.
By GTK48 in forum Windows tweaking and Management AppsReplies: 6Last Post: October 12th, 2011, 07:28 PM -
Repair Windows 7 Boot Problems Using Startup Repair
By razorsedge in forum Installation & SetupReplies: 0Last Post: July 29th, 2010, 12:31 AM
Theme request
