March 1st, 2011 06:09 AM #1
Fix: Unable to boot the System with error code 0×490, with W
Sometime when you boot your System you might get this error 0×490 and you won’t proceed from there. This happens if the Boot Manager is damaged or corrupted. In such a case, what we have to do, is we could run a Startup Repair.
To do so:
* Insert the Windows 7 installation disc or USB flash drive, or a system repair disc, and then shut down your computer.
* Then restart your Computer
* When prompted, press any key, and then follow the instructions that appear
* On the Install Windows page, or on the System Recovery Options page, choose your language and other preferences, and then click Next.
1 400x300 Fix: Unable to boot the System with error code 0x490, with Windows Startup Repair
* Click Repair your computer.
* Select the Windows installation you want to repair, and then click next.
2 400x308 Fix: Unable to boot the System with error code 0x490, with Windows Startup Repair
* On the System Recovery Options menu
3 Fix: Unable to boot the System with error code 0x490, with Windows Startup Repair
* Click on Start Repair
* Startup Repair would run the Repair process
4 400x308 Fix: Unable to boot the System with error code 0x490, with Windows Startup Repair
* After the process is over and fixes are applied, the computer would be re-started.
On some occasions, we might need to run the Repair, 3 or 4 times to create the boot files to new location. Each time we have to restart the PC.
Unable to patch system files with Windowblinds 8 installed ?
By Ghost Rider in forum Windows 8 & 8.1 Theme Help & SupportReplies: 17Last Post: October 23rd, 2014, 07:15 PM -
file error system 665535
By LiquidIce66 in forum General Windows 8 CustomizationReplies: 1Last Post: December 2nd, 2013, 01:24 AM -
Repair Corrupted Contacts Cache in WLM 2011: Error Code 8007
By razorsedge in forum General TutorialsReplies: 0Last Post: April 29th, 2011, 08:56 PM -
Fix: Error 16389, Unable to create the file New Library
By razorsedge in forum News & ReviewsReplies: 0Last Post: April 25th, 2011, 11:51 PM -
Fix: Error code 0x8007000D when trying to activate Windows 7
By razorsedge in forum News & ReviewsReplies: 0Last Post: October 11th, 2010, 09:32 PM
DWMBlurGlass App for...
