August 16th, 2011 08:19 AM #1
Windows Post-Install Wizard silent installer
Author: Kelsenellenelvian
https://www.wpiw.net/
License: Freeware
Requires: Win7/Vista/XP
Windows Post-Install Wizard (WPI for short) is a hypertext application designed for giving users choice. While Windows XP offers many ways of customizing the setup process out of the box, its major drawback is the lack of being able to select which applications an end user may install. In the past, end users and administrators needed to either download the files manually, or create overly complex scripts that could only be used once. WPI allows you to create one image, which can then be custom configured, and optionally, automated, so that end users can install any applications.
WPI is a simple to use automation program for the choice and installation of multiple programs, tweaks and scripts. No longer will you need a dozen CD's or more when doing a fresh Installation. No longer will you need multiple files when you are servicing another PC. With Windows Post-Install Wizard all that you will need is 1 or 2 CD\DVD's to fully install your PC with all of your apps, scripts, registry files or tweaks. Instead of having to re-download those apps like adobe reader, flash or updates to programs you can have them all on one disk. With WPI you can have all of them all on one disk and then have a nice interface for selecting which apps to install and after configured properly WPI will install all of them without any needed input from you. WPI also and is commonly used added to your windows installation disks. This way you can automate the complete process of Windows and program installations.
With your typical setup of WPI you have your OS and all of the apps, tweaks and such on one disk. After windows installs, WPI kicks in and you are given a selection of everything you have configured WPI with, then you can select the ones you want or simply let the timer run out and your default apps will install.
https://www.ryanvm.net/forum/viewtopic.php?t=9246
Seeking installer/wizard caption bar text and/or glow location
By ForumStumper in forum Explorer and shellReplies: 0Last Post: November 6th, 2021, 10:35 PM -
Wireless Wizard 5.0 silent installer
By razorsedge in forum Internet\NetworkReplies: 0Last Post: July 22nd, 2012, 08:22 AM -
Partition Wizard Home Edition silent installer
By razorsedge in forum Hard Drive ToolsReplies: 1Last Post: October 10th, 2011, 03:05 AM -
Windows 7 Tweaker 2 silent installer
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: November 3rd, 2010, 11:18 AM -
Windows Powershell x64 silent installer
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: August 5th, 2010, 10:33 AM
Post Your Mobile Theme
