October 3rd, 2011 02:44 PM #1GTK48Guest
Windows 7 In Place Upgrade Repair.
Source
If you purchased a retail copy of Windows 7, chances are your installation disc didn’t come with SP1 included. That means if you want to reinstall Windows 7 at a later date you’ll have to reinstall from the disc, then download all of those updates again, a time-consuming and frustrating process.
There’s another problem too: should you ever want to perform a repair installation of Windows 7 by choosing the “Upgrade” version, typically to fix a major system problem, then you’ll have to uninstall SP1 first from your computer before doing so – more time wasted and hair lost.
The answer lies in getting hold of a copy of the Windows 7 installation disc with the Service Pack 1 updates already included. You can do this manually using a tool called RT Seven Lite, but yet again it’s time-consuming, fiddly and – you guessed it – potentially frustrating.
Alternatively, you can download a legitimate image of the Windows 7 disc with the SP1 files already included. All you have to do is download the ISO file here, then burn it to disc by double-clicking the file and popping in a blank DVD when prompted. Once done, boot from the disc to verify it works and label the disc accordingly. You’ll need the product key that came with your computer to activate Windows 7 after reinstalling from scratch.
Note that this won’t work if you have a version of Windows that came pre-installed with your computer. Also make sure you download the correct version of Windows 7 for your needs – to find out which edition (Home Premium, Professional or Ultimate) and type (32-bit or 64-bit) you need, click Start, right-click Computer and select Properties.
how repair damaged windows 7 after bad theme installation
By sprne7gbs in forum General DiscussionReplies: 0Last Post: May 3rd, 2016, 01:21 PM -
Tweaking.com - Windows Repair silent installer
By razorsedge in forum Tweaking and TuningReplies: 5Last Post: November 12th, 2011, 12:52 AM -
How do Disable the annoying Windows 7 startup repair
By odinlives in forum Installation & SetupReplies: 0Last Post: February 10th, 2011, 07:13 PM -
Repair Windows 7 Boot Problems Using Startup Repair
By razorsedge in forum Installation & SetupReplies: 0Last Post: July 29th, 2010, 12:31 AM
Lightstar Can Be Very Protective Of His Creations As He Sends A Percentage Of Funds Made To Charities For The Poor, Best To Take This To PMs. As Its Premium, You Could Say "Inspired By" Or Something...
Theme request
