October 16th, 2011 09:45 PM #1
- 5,510
How to change System Properties (Left Bar)
Windows Se7en
Theme Resource Changer Tutorial
1.download and install application - Theme Resource Changer
you use 32 bit windows,install x32 bit version,for 64 bit,pls install x64 bit
2.go to windows themes directory - location is c/windows/resources/themes
3.create new folder and rename this new folder to Shell32.dll
4.copy/paste here your PNG - (Portable Network Graphics file)
5.rename this your original image to number 633
With using this very nice and easy application you can add
and modify more the system folders/files,cursors,icons
sound schemes,fonts,explorerframe.dll,imageres.dll,shell32.dll files
without unnecessary backups and without replacing the system files
who contacted me through a private message,here's a short guide how to do it
and here are my last help for member
NoVa x
https://virtualcustoms.net/showthread...677#post198677
original V.C thread and tutorial how to use
this amazing application by
razorsedge
Theme Resource Changer no more dll editing..
https://virtualcustoms.net/showthread...re-dll-editing..
How to use theme resource changer
https://virtualcustoms.net/showthread...source-changer
Please, before use, carefully read manual
https://www.mediafire.com/?87t13ja8cg71a44
How to change taskbar position to top, right, left, or bottom on Windows 11
By ミறѳѳղղįզվદ彡 in forum General Windows 11 CustomizationReplies: 3Last Post: May 3rd, 2022, 10:09 PM -
how change image left panel in system properties
By chevalierxx in forum Windows 10 Theme Help and SupportReplies: 3Last Post: August 15th, 2020, 09:02 PM -
How to change System properties logo in Windows 10
By poweredbyostx in forum General Windows 10 CustomizationReplies: 23Last Post: July 1st, 2018, 08:10 AM -
System Properties Orb
By Cashis in forum MiscellaneousReplies: 44Last Post: September 16th, 2015, 12:34 PM -
System properties of windows 8.1
By captain_majid in forum Miscellaneous questionsReplies: 0Last Post: November 2nd, 2014, 03:39 PM
Custom Class Maps and...
