Thread: AIMP v3.00 Build 976 FINAL
December 31st, 2011 06:22 AM #1
- Jun 2011
- Only FBI Knows :)
- 938
- 18 Post(s)
- 287 Thread(s)
AIMP is a powerful audio player that allows you to listen to your favorite music with an outstanding sound quality. Its appearance resembles that of another classical audio player (Winamp), so you’ll get used to it very quickly. It can also be customized with skins. The program includes a 18-band equalizer, a visualization window to display rhythmic visual effects and a playlist editor to organize your audio files. A nice fading effect makes your list of songs look like an endless music loop and a handy volume normalizing feature avoids drastic volume changes between tracks. Also, the player’s main functions can be conveniently controlled by global hotkeys. Besides playing music, AIMP features three extra utilities which also enable you to record any sound on your computer, convert audio files from one format to another and view or edit tags. AIMP is based on the well-known audio engine BASS, so it’s easy to connect new plug-ins (from the plug-in library included in the program) and expand the player’s functionalities.
• Audio Lirary, Sound Recorder, Audio Converter/CD Grabber and Tag Editor…
• Support for large number of formats and playlists …
• Work with multiple playlist immediately, creation of bookmarks, playback queue …
• Design Great functionality and user-friendly interface …
Main features:
* Audio formats supported: MP1, MP2, MP3, MPC, MP+, AAC, AC3, OGG, FLAC, APE, WavPack, Speex, WAV, CDA, WMA, S3M, XM, MOD, IT, MO3, MTM, UMX
* Good functionality and friendly user interface
* 18-sliders equalizer and build-in sound effects: Reverb, Flanger, Chorus, Pitch, Tempo, Echo, Speed
* 32-bit sound processing: for crystal clear sound
* Works with few playlists: Listern one, work with other
* Plug-Ins support: You can add new utils or extend already exists, and connect some winamp plugins: Input, Gen, DSP
* Autoshutdown manager
* Internet-Radio: Listern and Capture!
* Bookmarks and Queues
* Hotkeys: Customizable local and global hotkeys
* Multilingual interface
* Multiuser mode support: Few users works unders one computer? It’s no problem!
* Full Unicode support
* File search: File search by all opened playlists
* Many program options
* Small distributive size
* Audio Converter: Any supported audio file can be encoded to WAV, MP3, WMA or OGG format
* Audio Grabber: Audio CD Track can be encoded to WAV, MP3, WMA or OGG format
* Sound Recorder: Capture sound from any audio device in your system to mp3, ogg, wav or wma format
* Advanced Tag Editor: Edit ID3v1, ID3v2, Vorbis, WMA tags. Grouping rename, group editing and sort files by one of templates.
* Audio Library
Changes in AIMP v3.00 Build 976 (30.12.2011):
+ Basque localization was added
* Localizations were updated
* Player: Radio station name is now set automatically on starting playback, if it has not been set before by the user
* Tag Editor: Track number is no longer stored in the ID3v1, if it value more than 255
- Fixed: Player – part of the next track sounds in the end of current track, if “shuffle” mode is active
- Fixed: Player – “A-B Repeat” function drops playback position to beginning in some cases
- Fixed: Tag Editor – buttons in footer panel doesn’t display, if height of the screen less than 600 pixels
- Fixed: Tag Editor – the table doesn’t update after using tag autofill function
- Fixed: Plugins – last.fm plugin doesn’t start scrobbling sometimes
- Fixed: Small bugs and defects
AIMP HUD - FINAL (recolor proof)
By gor17981 in forum AIMP3Replies: 46Last Post: January 29th, 2021, 07:09 AM -
Creating an Aimp Skin with the aimp skinner app video tutorial
By razorsedge in forum Windows 7 Theme Help & SupportReplies: 18Last Post: October 15th, 2019, 02:00 PM -
darkfox final
By robyroby in forum robyroby's Windows 7 ThemesReplies: 10Last Post: April 16th, 2015, 04:07 PM -
Case build, the most awsome build ever
By designfjotten in forum Chill Out RoomReplies: 19Last Post: August 3rd, 2012, 04:50 PM
