July 22nd, 2012 01:14 AM #1
Silverlight switchless/silent installer maker
Silverlight switchless installer maker
file size: 1,27 MB (1.339.701 bytes)
md5: 715B06DD07FF6BE75D7A7C5AE67F8F8D
This tool will:
1. automatic download latest Silverlight installer (Silverlight.exe) from M$ site.
2. ask you from one GUI, how to install Silverlight*
3. extract files from Silverlight installer.
4. apply msp patch contained into setup package, Silverlight.msp over Silverlight.msi
5. depending on yours option one reg file will be created and added to installer.
6. compress this files back as one switchless installer.
7. also, get version and RC strings (FileDescription,FileVersion,etc) and add
all this strings, (by reshacking 7zSD.sfx resource), to final sfx file.
8. and generate one file SFX_Silverlight_%version%.md5, close to final sfx,
containing filename, file size and md5 for the final sfx produced.
* The GUi will ask for:
1. registry to add - move mouse over every radio/check box, one tooltip will explain what every reg key do.
2. you can choose if you want or not shortcut, and if this shortcut can be moved to Programs\Other Tools folder
(this is my usual option, so if you don't like, just don't use)
If you choose no shortcut or changed shortcut, maker will apply one transform to the msi file to make changes.
Your options will be stored into one ini file, "Binary\Silverlight.ini", so, next time will start with your old (stored) options.
Press GO! to create the sfx, press EXIT or just close maker window (X) to exit from maker.
Also you can use Esc key to Terminate maker process if something wrong happens.
You can edit/change the following:
1. change the icon (by replacing "Binary\Silverlight.ico")
2. change how sfx install process look (edit sfx config file: "Binary\silverlight.txt")
3. in the future, if download link will be changed, edit "Binary\Silverlight.ini"), line Link=https:// ....
https://www.ryanvm.net/forum/viewtopic.php?t=9380
Funny Photo Maker silent installer
By razorsedge in forum GraphicsReplies: 1Last Post: August 4th, 2012, 07:22 PM -
KMPlayer silent install maker
By razorsedge in forum Silent install creator appsReplies: 0Last Post: July 22nd, 2012, 06:34 AM -
SFX Maker (Silent Install Maker) 1.2.1 x86 and x64 silents
By razorsedge in forum Silent install creator appsReplies: 0Last Post: March 6th, 2011, 07:28 AM -
Silent Maker
By eoghan in forum RequestsReplies: 0Last Post: January 28th, 2011, 10:28 AM
Hello world, I am...
