Results 1 to 2 of 2
December 3rd, 2012 11:25 PM #1
How to Delete the Windows.old folder
Remove the Previous Windows Installation after Upgrading to Windows 8
You can remove the Windows.old folder to remove all traces of the previous Windows installation and also recover disk space.
When you upgrade to Windows 8, the program files and folders of the previous Windows installation are moved to the Windows.old folder.
If the Windows 8 upgrade happened smoothly and all your programs are working as expected, it may be a good idea to get rid of the Windows.old permanently as it could be holding tens of Gigabytes of precious disk space.
How to Delete the Windows.old System Folder
Windows.old is a Windows System folder and hence it cannot be removed using the good old Shift+Delete keyboard shortcut. However, Windows does include a utility to help you get rid of this bulky folder forever. Here’s how:
- Press the Windows key + R shortcut to open the Run box. Type cleanmgr here and hit Enter to open the Disk Clean utility.
- Select the drive letter where your Windows 8 is installed (most likely C: drive)
- On the next screen, click the button that says Clean Up System Files.
- The utility will rescan your C: drive but this time, it will add a new option that says “Previous Windows installation.” Select that option and click the OK button.
Just something i found.....
I thought this was rather funny !!!!!Last edited by peter.pan; December 5th, 2012 at 10:18 PM.
How To Delete Windows 7 Product Key From Registry
By razorsedge in forum General TutorialsReplies: 0Last Post: December 11th, 2010, 12:01 AM -
Add Copy, Paste and Delete Buttons to Windows 7 Explorer too
By razorsedge in forum General TutorialsReplies: 0Last Post: December 10th, 2010, 11:26 PM -
How to delete EVEN the Flash Cookies in Windows!
By razorsedge in forum System, Junk, Reg CleanersReplies: 0Last Post: October 5th, 2010, 04:05 AM -
Windows Installer folder : To delete, or not to delete; that
By razorsedge in forum Installation & SetupReplies: 0Last Post: September 16th, 2010, 09:42 PM -
How To Delete Corrupted Windows Media Player Library
By razorsedge in forum Setup TutorialsReplies: 0Last Post: August 12th, 2010, 11:05 AM
DWMBlurGlass App for...
