Thread: Modern Tile Maker for Windows 8
December 7th, 2012 02:22 AM #1
We are pleased to released Modern Tile Maker, a freeware for Windows 8 that will allow you to create Modern or Metro style Tiles for Files, Folders, Desktop Programs, Web links and more. When you create a shortcut of any folder or software on the start screen, it takes on the default form. But using Modern Tile Maker, the tile actually appears like a Metro UI tile – similar to how the Metro apps tiles look.
All you need to do to customize the looks is:
- Browse to the folder, file, .exe file, etc.
- Select the display name if you want to display it
- Select display color for the name
- Select Tile image Select Tile color.
Once you have installed Modern Tile Maker, run it and set your choices, check the Preview, and if it meets your preferences, click on Pin to Start. You will now be able to see the App-style tiles for your legacy applications, files and folders too. You can create Tiles with Modern UI for My Computer, built-in Windows tools and all other elements too.
There are some ready-to-use Transparent Tile Icons that have been included along with the download. These number over 100 and come in 2 styles.
- Transparent for use with Text: Images are slightly shifted upwards to allow for Text at bottom right corner. You will find them in this folder: C:\Program Files\MTM\Tile Images\Transparent Centered No Text
- Transparent for use with No Text: Images are centered giving a better appearance when not using Text on the Tile. You will find them in this folder: C:\Program Files\MTM\Tile Images\Transparent Shifted Text
Tiles you create will be stored in C:\Program Files\MTM\Tile Images\User Created Tiles
The size of the Tiles are 150×150. Larger images will be scaled down to fit. The process of generating the Tile images is efficient and pretty good at keeping the image quality without any loss. We recommend using Transparent Images as it gives a better option of selecting colors for the Tile. The option for Wide Tiles is currently unavailable.
Features in a nutshell:
- Add any File type to the Start screen. Files such as Images launch using their default program.
- Add any Directory(Folder) to the Start screen.
- Add Web Shortcuts to the Start screen. Just enter the address of the webpage you want the shortcut to direct to.
- When you begin to create the Tile you will be prompted to select your default browser. Choose the Text to display on the tile, Text Fore-color or choose to not display Text on the tile.
- Choose a Color for the tile which is shown if the image selected is transparent or not 150x150px
- Creates a Backup the tiles settings to allow you to Edit the tile whenever you choose.
- Creates a Backup of the Tile Image you create for use with other tiles.
- Includes 100 Transparent Tile Images formatted for use when displaying text or not displaying text (200 total images).
NOTE: If you make any changes to your computer or something just goes wrong and all of a sudden your Tile Icons display a standard Desktop icon instead of the Modern (Metro) Tile, load the application and click the Refresh Button. Give the Start Screen about 30-60 seconds to refresh itself and see if the tiles refresh themselves back to the Modern (Metro) Tile. If no changes still, Restart your computer and see if it reverts the changes back. If all this fails you will may have to unpin the tiles from the Start Screen, open the application and re-pin them using the backups that were created.
homepage/download: https://www.thewindowsclub.com/modern...aker-windows-8
Modern IE Launcher for Windows 10
By hb860 in forum Windows rumors and upcoming releases.Replies: 5Last Post: October 3rd, 2014, 12:38 PM -
Windows 8 / 8.1 live tile transparency
By Dark Knight in forum General DiscussionReplies: 2Last Post: November 4th, 2013, 08:27 PM -
How To Add Shutdown Tile To Start Screen In Windows 8
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 03:23 AM -
Shark007's Windows 7 Codec Pack Maker.
By razorsedge in forum Silent install creator appsReplies: 0Last Post: July 22nd, 2012, 01:06 AM -
SFX Maker (Silent Install Maker) 1.2.1 x86 and x64 silents
By razorsedge in forum Silent install creator appsReplies: 0Last Post: March 6th, 2011, 07:28 AM
Thanks so much :)
Customize icon
