December 8th, 2012 01:35 AM #1
OblyTile change the color of tiles in windows 8 start screen
his program is meant to create tile to the windows 8 start screen.
I created this in vb.net using SharpDevelop, it works for all programs/folder/files and even websites.
The program will store the image files inside the folder "C:\Program Files\OblyTile" and create the Shortcut .LNK file inside the StartMenu folder.
If you want to delete a Tile, right click it on the startmenu and select "Remove From Start" on the left bottom side.
Old Version:
OblyTile v0.5 (ChangeLog)
OblyTile v0.7/0.7.1 (ChangeLog)
OblyTile v0.8 (ChangeLog)
OblyTile v0.8.2 (ChangeLog)
OblyTile v0.8.6 (ChangeLog)
Latest Version:
OblyTile v0.8.8
ChangeLog:
- Added basic preview for tiles. (This is not very accurate, but works)
- Added support for others "primary" image format.
- Added option to change text colour.
- Added Quick List. (Thanks dAKirby309 for the tile images and for the OblyTile icon)
- Added donation button.
- Small Tile image is now optional.
- Images bigger than 200kb will be auto resized to 120x120.
- Shortcuts .lnk will now be stored on: %localappdata%\Microsoft\Windows\Application Shortcuts (This will prevent the shortcut to be listed on alternative shell like "Start8") (Thanks HungariaHitman for the tip)
- Improved Color Picker.
- Improved Tile Manager. (Thanks TheDriftQueen for the help)
- Run as administrator is now handled by the Launcher.vbs.
- Fixed missing image when zoom-out the start screen.
- Small changes to the Gui.
- Experimental: Added Windows Apps to Shortcut function. (Create shortcuts on desktop to open Windows Apps, a generic icon will be used)
- Experimental: Web browser can now be opened as Immersive. (Use the Quick List to create the tile)
Warning: Do not use "OblyTile App Launcher.exe" for external projects.
Note Issues:
- In order to launch the Immersive mode of your web browser by using a tile made with OblyTile, be sure to close the desktop version of it.
- If you want to use OblyTile on accounts without administrator rights, you must create the folder "OblyTile" inside C:\Program Files\ and put full access on it.
- If the tiles are not showed properly (a normal icon is showed) open OblyTile and press the second button on top of OblyTile. (Rebuild cache)
- If the tiles will not react when you click it (the program or file will not be opened) follow those steps VBScript - Fix
Tested on:
Windows 8 Professional Build 9200 - 32/64 Bit
Windows 8 Enterprise Build 9200 - 32/64 Bit
homepage/download: https://forum.xda-developers.com/show...14&postcount=1
How to enable classic Start menu with Live Tiles on Windows 11
By ミறѳѳղղįզվદ彡 in forum General Windows 11 CustomizationReplies: 1Last Post: October 31st, 2021, 11:07 AM -
How do I change the text color of the All Programs tree in the start menu
By hunterxd408 in forum Start MenuReplies: 2Last Post: May 22nd, 2021, 11:22 PM -
Windows 8 Start Screen Tiles [rows adjuster]by ~vhanla
By razorsedge in forum Customization ToolsReplies: 1Last Post: October 13th, 2014, 07:50 PM -
Start Screen Color Tuner
By hb860 in forum Windows 8.1 Customization ToolsReplies: 3Last Post: November 22nd, 2013, 06:31 PM -
Change Blue Screen Of Death (BSOD) Color Using Not My Fault
By razorsedge in forum MiscellaneousReplies: 0Last Post: January 13th, 2011, 11:24 PM
Thank you:happy::happy:
Office 16 64-bit Color...
