December 8th, 2012 03:23 AM #1
How To Add Shutdown Tile To Start Screen In Windows 8
Shutting down Windows 8 can be frustrating as it’s no longer possible to access all shut down options with a click. In earlier versions of Windows, one could just open the Start menu by pressing or clicking the Start orb to access all shut down options.
n Windows 8, one needs to open the Settings charm by moving mouse cursor to the upper-right or lower-right corner of the screen, and then clicking Settings to access shut down, restart, hibernate, and sleep options. While it’s possible to access the settings charm with the help of Windows logo key + I hotkey, users who prefer mouse need two more seconds to access shut down options. Users can also access Windows Shut Down dialog from desktop by clicking Alt + F4 keys.
There are a number of workarounds available to easily access shut down options in Windows 8. You could add shut down options to the Windows + X menu (the menu that appears when you press Windows + X hotkey), add shut down options to desktop context menu, or pin shut down to the Start screen.
A lot of Windows users like to pin shut down tile to the Start screen for the quick access. Users who don’t mind installing a small program can follow our how to pin shut down, restart, hibernate and sleep options to the Start screen. But if you want add shut down option to the Start screen without using third-party tools, you need to follow the given below procedure.
Procedure:
Step 1: First, we need to create a shortcut for shut down option. To do that, right-click on desktop, click New and then click Shortcut to open Create Shortcut wizard.
Step 2: In the location of the item you need to type the following value:
To create shutdown shortcut:
shutdown.exe -s -t 00 –f
(Use given below values if you want to create shortcuts for restart & hibernate)
To create restart shortcut:
%windir%\System32\shutdown.exe –r
To create hibernate shortcut:
C:\Windows\System32\rundll32.exe powrprof.dll,SetSuspendState 0,1,0
(replace “C” with your Windows 8 drive letter)
Step 3: Click Next button. Enter Shut down, Restart, or Hibernate (depending on for which you’re creating shortcut) in type a name for the shortcut box and then click Finish button.
Step 4: Once you have the shortcut on your desktop, right-click on the shortcut and click Properties.
Step 5: Under Shortcuts tab, click Change icon button to browse to an icon file that suites your shortcut. If you want metro-style icons, we suggest you check out our 500+ Metro-style icons for Windows article.
Step 6: Select an icon, click Ok button and then click Apply button.
Step 7: Finally, right-click on the shortcut and click Pin to Start to create your own shut down tile on the Start screen. Your new tile should now appear on the Start screen. You may move the tile from the end to the beginning of the Start screen for quick access.
article page: https://www.intowindows.com/shutdown-...-start-screen/
Windows 8.1 wallpaper / start screen / lock screens
By Dark Knight in forum Wallpapers Posted by Dark KnightReplies: 1Last Post: July 19th, 2014, 12:50 PM -
Windows 8 Start Screen Defaults
By YourNumbr1Fan in forum General Windows 8 CustomizationReplies: 4Last Post: March 27th, 2013, 11:06 PM -
Enable Hidden Start Screen Animation In Windows 8
By razorsedge in forum Tips and TricksReplies: 4Last Post: December 8th, 2012, 03:23 AM -
How To Reduce Start Screen Size In Windows 8
By razorsedge in forum Tips and TricksReplies: 0Last Post: December 8th, 2012, 02:05 AM -
How to add administrative tools to the Windows 8 Start screen
By razorsedge in forum Tips and TricksReplies: 0Last Post: December 6th, 2012, 11:43 PM
Hello world, I am...
