Results 1 to 4 of 4
Thread: Blue Overview
February 7th, 2013 06:47 PM #1
- Dec 2012
- Earth
- 21
- 13 Thread(s)
Blue Overview
I was recently introduced to Rainmeter and really love it. I decided to combine skins from different suites and tweaked them into a single suite. Hope you like it as this is my first attempt
Additional Applications:
Below is the list of applications that are needed to ensure that all components of the skin work properly. Do note that if any application is not installed, the skin will have missing data but will not cause any issues or system instabilities.
Core Temp ([link])
MSI Afterburner ([link]) for Nvidia/AMD GPUs
SpeedFan ([link]) On Windows 8, select compatibility for Windows 7 for installation ([link])
Instructions:
Manual tweaking for some of the skins are required due to the unique configuration of each system. Please note that I have marked those sections clearly and provided instructions where necessary. For further information, please read the easy-to-understand Rainmeter guide ([link]). I might be able to provide some help if possible, however, Google seems to know the answer to almost all questions if asked nicely
Skins Available:
Below is the list of available skins
Application
- 10 customizable shortcuts
- Left click central orb to hide/show shortcuts
- Middle click central orb to load/unload skins layout
NOTE: Once you have loaded all the required skins, you must save the new layout with the name "Blue Overview" which will overwrite the default layout (which has the same name) and you will have your desktop layout permanently saved [link]
Battery
- When charging, shows the charge level as percentage
- When running on battery, shows the time remaining
CPU
- Shows total CPU usage as percentage and graph
- Shows CPU Model (Core Temp required)
- Shows current CPU speed (Core Temp required)
- Shows maximum temperature (Core Temp required)
- Shows top 3 process name and values
GPU
- Shows core frequency (MSIAfterBurner required)
- Shows driver version installed (MSIAfterBurner required)
- Shows fan speed as percentage (MSIAfterBurner required)
- Shows GPU model (MSIAfterBurner required)
- Shows GPU temperature (MSIAfterBurner required)
- Shows GPU usage as percentage and graph (MSIAfterBurner required)
- Shows memory frequency (MSIAfterBurner required)
- Shows PCB temperature (MSIAfterBurner required)
- Shows shader frequency (MSIAfterBurner required)
- Shows used VRAM as value and bar graph (MSIAfterBurner required)
Storage (HDD/SSD)
- Auto hides when drive is not present (for removable drives)
- Shows the drive letter and name
- Shows the free, used and total capacities as percentages and values of the HDD/SSD
- Shows the temperature of the HDD/SSD (Speedfan required)
- Shows the transfer rate as values and graph
Storage (USB/RAMDisk)
Storage (ODD)
- Auto hides when drive is empty
Media Player
- Auto hides when media player is closed
- Provides some control of the configured media player
- Shows the title, artist and album of the currently playing track
Network
- Shows the total upload and download stats
- Shows the upload and download rates
Power Panel
- Hidden by default to prevent accidental clicks
- Shows the uptime
- Support for shutdown, restart, hibernate, logoff, lock and sleep
RAM
- Shows the free and used as percentages and actual values
- Contains an editable line of text which can be used to display the RAM model information
- Shows top 2 process names and values
- Shows total RAM
Recycle bin
- Shows the total number of items
- Shows the total size
Time Zone
- Shows the day and date of the time zone configured
Special Thanks & Credits:
Below are the list of authors who have helped me and/or whose work I have used:
~g3xter For giving me permission to mod his skin, for the prompt and kind email replies and creating the wonderful icons for SSD, USB, ODD, RAMDisk [link]
~aroche For giving me permission to use the recycle bin icon [link]
ch_rob @ Rainmeter Forum: For allowing me to use his TopProcess plugin [link]
DigitalDJ @ Rainmeter Forum: For allowing me to use his TopProcess plugin [link]
~Kaelri For helping me with some of the coding
~Mordasius For helping me with some of the coding
~newmanhyde For making a wonderful battery skin [link]
~Seclipse For giving me permission to mod his skin [link]
Stangowner @ Guru3D: For giving me permission to mod his skin and allowing me to use the MSI Afterburner plugin [link]
~UrulokiBurning For making the wonderful Mass Effect skin [link]
~Zeek-Aran For making the wonderful Mass Effect skin [link]
*z-design For making the tech brushes [link]
And last but not the least, the wonderful people at Rainmeter Forum for guiding me.
Note: Feedback and suggestions are welcomed. Moreover, please inform me if you use my work/part of it anywhere else
February 7th, 2013 07:05 PM #2
- Feb 2010
- Cornfeilds of Indiana
- 2,528
- 21 Post(s)
- 298 Thread(s)
Very nice set up bud, Thanks for sharing with the community
Please Post In English OnlyDon't forget to leave Comments and Rep to the artist if you like or use their artwork.
Thanks VC Staff
February 8th, 2013 12:03 AM #3
- Dec 2012
- Earth
- 21
- 13 Thread(s)
July 17th, 2013 01:20 PM #4
- Oct 2012
- Virtual Customs
- 1,672
- 337 Thread(s)
Damm this is so futuristic, love it, but i think my pc will burn after apply it, thank you for sharing and for hard work, respect!
7tsp Shadow Blue and Digital Blue Icon Pack v1-v4 for Windows 7 w8 8.1 w10 w10 19h1+
By ミறѳѳղղįզվદ彡 in forum 7tsp Icon PacksReplies: 10Last Post: September 22nd, 2020, 01:20 AM -
Orb HUD Blue
By sete in forum Start OrbsReplies: 0Last Post: November 20th, 2016, 02:57 PM -
In Blue
By Stephanie in forum Wallpapers posted by StephanieReplies: 3Last Post: October 19th, 2016, 04:17 PM -
Get the Blue Out
By gsw953 in forum gsw953's Windows 7 ThemesReplies: 15Last Post: March 27th, 2012, 06:38 PM -
Blue UV
By mauam in forum Screen Savers & Dream ScenesReplies: 9Last Post: September 14th, 2011, 05:13 PM
Thank you:happy::happy:
Office 16 64-bit Color...
