Thread: Gray8 Blue High Contrast mode
March 30th, 2013 02:46 PM #1
When I first released Gray8 Mark suggested I do a high contrast vesion
so here it is!
This is the theme I use the most and
I thought some of you other minimal theme fans might like it too!
Your system must be patched to allow 3rd party themes
To install copy the Blue HC folder and .theme file to your Windows\Resourses\Themes folder
and then apply it from your Contol Panel\Personalize window
Everything will get themed!
including the Start Page and Login Screens
I use Ribbon Disabler
but you don't need to as the ribbon will also be themed
You will probably want to disable "Animations in Taskbar as I couldn't remove the flash background(yet)
To do this go to System Properties\Performance Options and uncheck it
Over the next few weeks I will be adding extra's
Like a patched ExplorerFrame to allow for images in the Explorer backgound
The custom imageres.dll I use for the system icons
along with many more custom files
The wallpaper shown in the preview is a modified version of Sublimo
by my good freiend Merrdyn,stop by and check out all his other awesome work too !
The other wallpaper included in this theme is by Vigoni
The icons used are Token by brsev
and were manually changed
If you want to change the clock grab the time\date cpl from the Gray8 color pac
Gray8 High Contrast mode
Windows 10 Dark mode mode Ribbon
By ceo54 in forum Windows 10 Theme Help and SupportReplies: 6Last Post: March 1st, 2021, 05:07 PM -
Lightweight High Contrast or at Least Fully Black Theme
By masawins in forum General Windows 7 CustomizationReplies: 3Last Post: September 20th, 2016, 11:15 PM -
How to tell if Windows 8.1 runs in UEFI mode or in the Legacy BIOS mode
By Originalganjaman in forum General TutorialsReplies: 0Last Post: February 3rd, 2014, 12:34 PM
Thank you:happy::happy:
Office 16 64-bit Color...
