Results 1 to 5 of 5
Thread: problems with display
Hybrid View
June 3rd, 2013 04:05 PM #1
- Mar 2010
- foley, mn, us
- 196
- 24 Thread(s)
everytime i log off or reboot, my display changes my screen res, and i havve to change the resolution manuelly. it is almost like it is not saveing my settings. what can I do? it is getting very old.
If you share my work Please give credit or refer to my gallery https://sounddevil13.deviantart.com
June 3rd, 2013 04:15 PM #2
Very strange, sounds like a registry problem maybe, best guys to talk to about that would be these guys at sevenforums https://www.sevenforums.com you may need to do a repair install.
June 3rd, 2013 04:55 PM #3XxHackThisxXGuest
you might want to try ah clean boot to see if you could resolve the problem.It could be something in your startup through the msconfig utility that might be causing the problem.You could also try disabling live mesh as it is not needed and can also cause problems.Do you have any games installed? sometimes games use ah different resolution and if any part of that software is booting then it will change your resolution also.You could also check to make sure program compatibility service is disabled or enabled through the administrative services.Also make sure your graphics card is up to date.Hope this helps.good luck
June 3rd, 2013 05:10 PM #4XxHackThisxXGuestIf that doesnt help,then you should also check this as it might be your problem..1. Click the “Start” (orb-like) button.
2. Type “msconfig”(without the quotes) and press enter.
3. You’ll get a small window. In that select the “boot” tab.
4. Under that select your operating system(it would be selected by default unless you have a dual-boot).
5. Make sure the “Base Video” option is UNCHEKED.
6. Apply the settings and then reboot your system after setting your desired resolution.
7. I hope this solves your problem!
Make sure you select the desired resolution BEFORE you reboot.
June 3rd, 2013 05:18 PM #5
Check your display driver(s) , may be corrupt or out of date.
Having Problems getting taskbar and windows to display correct content
By Zaitoa in forum General Windows 10 CustomizationReplies: 1Last Post: July 25th, 2020, 07:36 AM -
By Zaitoa in forum General Windows 10 CustomizationReplies: 1Last Post: July 25th, 2020, 07:21 AM -
Problems with the site
By Mr GRiM in forum Requests, Site Problems and FeedbackReplies: 539Last Post: May 14th, 2020, 01:30 AM -
Theme Problems!!!
By pidgetpn in forum Theme IssuesReplies: 11Last Post: December 10th, 2017, 09:11 PM -
white box problems
By deviantdon in forum Windows 10 Theme Help and SupportReplies: 5Last Post: June 11th, 2017, 04:24 PM
