July 2nd, 2013 09:49 PM #1
- Sep 2010
- Niagara Falls,On.,Canada
- 146
- 14 Thread(s)
Full Glass Blue Icon Pack 7600 uninstalls but won't change to Windows default icons
I installed Grim's Icon Pack that changes the folder icons in Windows 7 using the installer. With the pack comes an uninstaller command so you can change back to the default icons and delete the backups. It is a must to run the uninstall and cleanup command if you want to install again or install something else. I ran the uninstall cmd today and it ran ok because when I tried to run it again it said it would only run if it was installed so it wouldn't run a second time, which means it must have worked the first time but the installed icons must not have got the message because they are still installed. The icons are from Grims icon pack and they always worked fine before all across the board. I even ran the cleanup cmd and everything prompts like it worked, but the folders are still there. I was wondering if someone knows how I can get the Windows folder icons back to default without a reformat?
Blue Glass icon pack
By ミறѳѳղղįզվદ彡 in forum Custom IconsReplies: 13Last Post: January 4th, 2022, 02:29 PM -
iPack Full Glass Icons for Windows 10 Build 1709 +
By VistaKing in forum RequestsReplies: 37Last Post: November 10th, 2018, 03:44 PM -
Changing Hud Machine Blue Theme Icons Back To Default Windows Icons?
By darkdream787 in forum IconsReplies: 1Last Post: April 22nd, 2014, 12:07 AM -
Request: Full Glass Blue Icon
By pillou13 in forum Theme RequestsReplies: 2Last Post: January 31st, 2010, 10:55 AM -
Hello, download the blue glass icon pack is wonderfull! but
By bjarte in forum Custom IconsReplies: 1Last Post: November 24th, 2009, 02:32 PM
