August 20th, 2013 03:53 AM #1
Aero Glass For Win 8 by Big Muscle v1.2
The wait is over for Windows 8 users, the final build for Aero Glass has been released to early donators.
Aero Glass for Windows 8 is a free software with no limitations. If you feel that you like this application a lot, you can donate arbitrary amount of money. Technically, if you don't want to donate, you can still use Aero Glass library without any constrains application will just ask you to donate several minutes after execution. As a bonus, all donators automatically gets an unlimited access to any beta of upcoming versions and to any possible secret features.
The amount of donation totally depends on you, but if you donate at least 3 Euro you can use following form to generate license code for your computer. You can generate license code for two computers per each 3 Euro you donated. This form serves for recovering lost license codes too. Fill in your PayPal e-mail and machine code, press Generate button, store downloaded file to your Aero Glass folder and restart DWM process to activate your license.
I have decided to make my own installer for Aero Glass which you can use as an alternative, it has a couple of extras like AGTweaker included as well a safety precaution in the event that you uninstall Aero Glass and were using the Bypass Theme Signature for custom themes, my uninstaller will return you to the default Aero theme before completing the uninstall and asking you to restart to complete the changes, Big Muscles on the other hand will ask you to do a restart but if you were using a custom theme at the time then upon reboot you will be met with a black screen and need to do a system restore in the advanced repair options.
AERO GLASS for Win8 v1.2
* inactive frame blur/color balances are not altered by theme opacity settings when user set them manually
* blur deviation settings is applied everytime colorization is changed (so no DWM restart is needed now)
* custom theme resource can now be loaded globally from HKEY_LOCAL_MACHINE
* glass is disabled when running on a battery
--> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\DWMisableGlassOnBattery (DWORD 0x0 / 0x1 = default)
* implemented glass reflection (aero stripes only)
--> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\DWM:ColorizationGlassReflectionIntensity (DWORD 0x0 = disabled (default) / other values = enabled)
AERO GLASS for Win8 v1.1
As some users were requesting, I've implemented algorithm to generate gaussian blur offsets and weights:
* you can change blur deviation in HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\DWM:BlurDeviation (DWORD, default = 30)
* do not set it too high (low performance) or too low (glitchy look)
* setting blur deviation to 0 will result in transparent non-blurry frames
When you upgrade your CPU, you can now generate new additional license for free.
Download my Installer from the link below
Aero_Glass_RTM_v1.0.exe
Aero_Glass_RTM_v1.1.exe
Aero_Glass_RTM_v1.2.exe
New tool I made to tweak the Aero Glass Blur effect, also included in my installer.
Aero Glass Blur Tweaker v1.1 for Aero Glass for Windows 8
This is a simple little app that I made to toggle the various settings used with Aero Glass for Windows 8 by BigMuscle
Featured Settings:
EnableLogging: Enables logging / logging of license messages is always enabled
DisableGlassOnBattery: When your AC power is unplugged and computer is running on the battery then the blur effect will be disabled to decrease power consumption.
ColorizationColor
ColorizationColorBalanceInactive: The intensity of the color.
ColorizationBlurBalance
ColorizationBlurBalanceInactive: The amount of the opacity of the windows frames.
BlurDeviation: Standard deviation for Gaussian blur.
RoundRectRadius: Radius of rounded windows corners.
CustomThemeResource: Path to PNG file with theme resource.
ColorizationGlassReflectionIntensity: Aero stripes effect.
BypassThemeSignature: Allows the use of Custom unsigned themes.
Enable/Disable Aero Glass
Download here https://www.mediafire...BlurTweaker.exe
Or Download the Original installer for Big Muscle
setup.exe
setup-1.1.exe
I have 4 more machine code activations available and would be happy to give a couple of those to deserving members, if you would like to be one of the lucky ones then please post your machine code that is generated after 5 minutes in the comments below.Last edited by Mr GRiM; September 16th, 2013 at 11:10 PM.
August 20th, 2013 04:21 AM #2
Mark your installer worked perfectly
and the program seems to be prefect also!
here's my machine code MEXFS5LSLUYTTL75NGG7LQGW4MYL3BIV4GLLEBNA6L3CMAPA
August 20th, 2013 04:32 AM #3
August 20th, 2013 04:51 AM #4
August 20th, 2013 02:11 PM #5
- Jul 2013
- Wiesbaden
- 3
- 2 Thread(s)
Hallo,
fantastic work. I also get a Machine Code and need a License. My Machine Code is: 36CFCWLQSUQLJLOCR4F6LII6MDPL4VNLFHLFQ76YRL4JE3WQ
Please can you send me the license for my Machine?
Greets JK41
August 20th, 2013 02:44 PM #6
How to fix Aero Glass for RS4 bug
By poweredbyostx in forum General Windows 10 CustomizationReplies: 1Last Post: August 18th, 2018, 06:10 PM -
Aero Glass for Win8.1 v1.2.5 Copyright (C) 2013-2014 Big Muscle
By Mr GRiM in forum Customization ToolsReplies: 92Last Post: March 27th, 2016, 06:24 PM -
Aero Glass
By razorsedge in forum Customization ToolsReplies: 0Last Post: September 30th, 2015, 03:38 PM -
Aero Glass for Win8.1 RC1 by Big Muscle x86 x64 AIO
By Mr GRiM in forum Customization ToolsReplies: 8Last Post: December 12th, 2013, 11:33 PM -
Aero Glass PNG
By alienxpert in forum GraphicsReplies: 0Last Post: March 1st, 2011, 12:12 AM
Thank you Monica! You're the best
Visual C++...
