Results 1 to 6 of 10
August 20th, 2013 09:11 AM #1
Need help about Services's Dialog
I have used my iconpack installer to change icon windows 7 x64 but I have an error about Services's Dialog.
Screenshot:
Rightclick -> Select Properties but this dialog is error.
Screenshot original:
Do you know fix?
Thank!Last edited by khatmau_sr; August 20th, 2013 at 09:42 AM.
August 20th, 2013 09:27 AM #2
- Jan 2012
- las vegas, NV
- 798
- 260 Thread(s)
try this
1. go to control panel - user accounts - change user account control settings -> drag the button all the way down___ "never notify" = u have to be an administrator to do this (you can turn it back on later if you want)
2. re-install your iconpack
August 20th, 2013 09:44 AM #3
August 20th, 2013 10:02 AM #4
- Jan 2012
- las vegas, NV
- 798
- 260 Thread(s)
August 20th, 2013 10:24 AM #5This is my iconpack:
x86 is perfect but x64 is error. Have many files, I don't know what file? I try restore "mmc.exe" but still error. Hopy some body know name of file or how to fix error.
August 21st, 2013 02:09 AM #6
- Jul 2011
- Nowhere
- 947
- 10 Thread(s)
You should ONLY install the iconpack that is configured for your system bud! If you are on a 32-bit system, DO NOT use the 64-bit iconpack!--and vice-versa.
Now you need to open a command-prompt, type in "sfc /scannow" (without quotation-marks), restore your system-files, reboot, re-patch (making sure to disable UAC beforehand!)....THEN re-apply the CORRECT icon-pack that supports the type of system you are running.
Best answer I can give ya.
Textcolour in the Services Window
By vceu in forum Text Color LocationsReplies: 3Last Post: March 22nd, 2011, 11:18 PM -
See where Google’s services are blocked around the world
By razorsedge in forum News & ReviewsReplies: 0Last Post: September 22nd, 2010, 01:16 AM
Aegis Windows 11 Port...
