August 31st, 2014 11:56 PM #1
- 1,920
Problem with 'Armoured' Theme for Windows 8.1
Hello, I'm having a slight problem with the Armoured theme for Windows 8.1. Simply said, the rocket dock icons don't seem to work, and the program icons didnt apply completely(Not sure if the icons from the HUD Evolution theme interfered or so on). Here is a screenshot of the problem. Any ideas on why this happened and how to fix it?
September 1st, 2014 09:36 AM #2
- Oct 2012
- Virtual Customs
- 1,672
- 337 Thread(s)
First you don't have problem with Armoured theme, this is problem with your icons in Rocketdock application, complete diferent story mate!
Second, that rocketdock skin that i see on your screenshot is braking appart in your end cause you make it way bigger then designer make it for using (thats why you have breaked line in center of it, make it smaller).
To add icons my suggestion is go to your rocketdock / icons installation folder and add icons manually there, but remember don't add IconName.ico file type, they need to be png file type for example IconName.png so they can be displayed in that window where icons usually are! After this you should be good to go!If you like theme's & material's from Artist, give them support by reputation!
September 2nd, 2014 01:57 AM #3
- 1,920
wow, never noticed it was breaking rofl.. thanks for that, fixed the size issue
. as for the icons, they are all already png types and they still won't work.. not sure what's going on there. Do you think I might have to reinstall it to try to fix that? Either way, I'm currently improvising by using the select few that do work. You can see those in my post in Show Your Desktop III i believe the thread is called. I think the thread was posted by Mr GRiM. I'll edit a link into this post if I find it properly,
. Also as shown in the screenshot on this page, the system icons also didn't apply to everything. and i couldn't get any of the icons to show up when i went to apply them, despite seeing them in the .dll file when i opened it on it's own. Not sure what happened there tbh.
Okay, here's the link I mentioned. It leads to the page of which my post on the Post Your Desktop III thread is located on.
https://virtualcustoms.net/showthread...t=Show+DesktopLast edited by Nimbi; September 2nd, 2014 at 02:10 AM. Reason: Added the link I promised.
September 2nd, 2014 02:25 AM #4
- 1,920
Okay, I figured out why they won't work. Apparently they didn't download properly. Each of the images that don't work only downloaded the file extensions for them but not the actual images. Apparently they are each empty. I noticed this while going into the file and moving them back so as to put each one in manually. For some reason each of the image files are empty. Not sure what's causing that tbh. At the very least there are a few images that work. But most of them are empty for some odd reason.
September 2nd, 2014 03:52 AM #5
- 1,920
Okay, I fixed it. I had to uninstall the whole thing removing everything and then reinstall it. It's all working fine now.
Armoured Ultimate Theme Pack for Windows 10 19h1-21h2
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 6Last Post: July 2nd, 2022, 04:45 PM -
Armoured RW Theme for Windows 10 19h1 19h2 20h1 20h2 21h1 21h2
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 9Last Post: October 13th, 2021, 10:37 AM -
Armoured Windows 8.1 Theme
By Lamia in forum gor17981 Windows 8 ThemesReplies: 13Last Post: September 27th, 2015, 01:20 AM -
Armoured: Purple Edition Windows 8.1.1 Theme
By Lamia in forum gor17981 Windows 8 ThemesReplies: 8Last Post: May 27th, 2015, 05:40 PM -
Problem with Windows Theme Installer with the DeathStar Blue theme.
By hl2modrift in forum Theme IssuesReplies: 2Last Post: October 30th, 2011, 07:19 AM
No, theming UWP apps involves editing XAML files, not DLLs.
How do i change these...
