Results 25 to 27 of 27
Thread: Winaero Tweaker
    hb860 is offline
    Jul 2011
    Russia
    63
    9 Thread(s)
    My all-in-one software.
    I am going to do the following:
    1. To merge over 50 my tools to one app.
    2. To maintain and update it more frequently, providing support to new [Windows 10] builds and freshly discovered features.
    It supports Windows 10, Windows 8/8.1 and Windows 7 and offers the following options:
    Windows 10
    Change Windows Update behavior which is locked to "Install updates automatically" in Windows 10 Technical Preview.
    Enable the secret hidden experimental Date & Time pane which is not enabled by default in Windows 10 Technical Preview.
    Enable the secret hidden experimental Login Screen which is not enabled by default in Windows 10 Technical Preview.
    Switch between the old resizable Start menu and the new "Continuum" Start menu in Windows 10 Technical Preview.
    Appearance
    Tweak Aero colors (my famous "Aero Tuners" family is merged here)
    Customize Shortcut Arrow
    Customize Window Borders size
    ^these two above were also as standalone apps. Shortcut Arrow part's code is very improved now.
    Slow down window animations - that Shift key trick
    Sync Metro & Aero Colors(Windows 8/Windows 8.1)
    Operating system behavior options
    Disable "Look for an app in the Store" Notification(Windows 8/Windows 8.1)
    Disable New Apps Notification(Windows 8/Windows 8.1)
    Disable Aero Shake
    Disable Aero Snap - i coded this to disable it with one click. I do not like Easy of Access center journey.
    Boot and Logon options
    Disable Lock Screen(Windows 8/Windows 8.1)
    Don't display last login user name
    Verbose Logon Messages
    Enable CTRL + ALT + DEL logon requirement
    User accounts
    Disable or Enable UAC
    Enable Built-in Administrator
    Network options
    Enable Network Drives over UAC
    Enable TCP/IP Router
    Pining options
    Unblock "Pin to Start" for all files and folder in Win8/Win8.1
    Here are few screenshots:
    I will continue to improve the app. It will get more features and more "merged" apps from Winaero.
    I plan to release a new build weekly.
    Again, like my other apps, Winaero Tweaker is freeware. It does not require to be installed and works as portable all. Enjoy.
    The latest verion is Winaero Tweaker 0.2.1
    Change log
    Enable Jump Lists for Start menu in Windows 10 build 10041
    Default Drag-n-Drop action
    Drive Letters
    XMouse allows you to tweak mouse scroll behavior
    Download Winaero Tweaker
    The list of Winaero Tweaker features
    Winaero Tweaker FAQ
  1. Winaero Tweaker Tutorial
    By Erdenhengst in forum Tweakers
    Last Post: April 20th, 2020, 01:46 PM
  2. Winaero Tweaker
    By razorsedge in forum Customization Tools
    Last Post: February 24th, 2016, 06:33 PM
  3. Winaero WEI Tool: Windows Experience Index for Windows 8.1
    By hb860 in forum Windows 8.1 Customization Tools
    Last Post: May 27th, 2015, 05:06 PM
  4. Winaero XMouse Tuner
    Last Post: January 20th, 2015, 02:28 PM
  5. Winaero ColorSync
    Last Post: November 19th, 2013, 07:38 PM
