Results 1 to 6 of 9
Thread: UltraUxThemePatcher 2.5.10
May 13th, 2015 10:28 PM #1
- 5,510
Windows 7/8 , 8.1 and 10 Insider preview
Ultra UXTheme Patcher version 2.5.10 updated 1.5.2015
Supported for 32 Bit-System and 64 Bit-System
Windows XP, 2003, Vista, 2008, 7, 8 Windows 8.1 and 10 TP
Windows 10 Insider preview up to 10074
About
Many people know from experience, that the Windows design is nice, but sooner or later it will become boring and you wish to have a different design. And here is the problem, because to use 3. Party themes you have to modify some system files, which is not everybody's thing, or buy expensive software.All this has now an end because the UltraUXThemePatcher for Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, Windows 8, Windows 8.1 and Windows 10 (for 32bit and 64bit version) can do this automatically for you. Fast, free and without problems, because if your version should not be supported, the tool will recognize this and changes nothing.Functions
Note: This application make changes to your system files, this can lead to unexpected problems or total breakdown of Windows!
I am interested in any kind of feedback!
Forum (Winfuture)
- unproblematic installation
- fast, easy and free
- Modification of the own system files
- multilingual
- check the files for compatibility during the installation
- backup from the original system files
- rebuilding of the original system files through un-installation
- silent installation with parameter /S
Change log
2.5.10
- Support for 32bit and 64bit systems of Win XP, 2003, Vista, 2008, 7, 8, 8.1 and 10
- Support for Windows 10 (Insider Preview up to 10074)
- Better recognition of Windows 10
- During uninstallation the standard theme will be applied for Windows 8, 8.1 and 10
Download
- 01.05.2015
- UltraUxThemePatcher 2.5.10 (160469 bytes) 807250 download(s)
- MD5 checksum: 9c45715f340f2d4fa0d0830cbed5752d
- SHA1 checksum: a00a3d1b5ab7edc0130b1bd4a7bde155fd2fc8ff
Support the Project
Thank you for using my applications. If you like the software and use it regularly, the developer would be thankful for your donation! Your donation will support the development of new features and help to keep up a continuous program maintenance.FAQ
Everyone who has a problem after the installation of this application should first look into the FAQ for a solution.
If no solution worked for you please get in contact by Email and please do not spam into the guestbook for this.
Thanks.
Problem - Windows Updates broke various files (Windows 8)
After an update on Windows 8 the UxThemePatcher does not work anymore. How do I fix it?
Please use the latest versions available, there this problem was solved!
Problem - After uninstalling on Windows 8, the monitor remains black after restart
Every time I try to uninstall your application on Windows 8 or higher the monitor remains black after the restart. How can I fix this?
Before uninstalling always a standard Windows theme should be selected. Thereafter the uninstallation should be started. Is this too late, only a repair installation (inplace upgrade) or a complete new installation helps.
Problem - Completely undo changes
I want to completely undo the changes done through the application. How do I do it best?
First, always a standard Windows theme should be set, otherwise it may cause problems when booting (see problem 2). Thereafter, the application should simply be removed through software -> uninstall. All backups will be restored so the original files are back!
Problem - Display errors in the taskbar after update to Windows 8.1.
After upgrading to Windows 8.1, there are display errors when right clicking on the applications in the taskbar. How can I fix this?
Themes of Windows 8 are not compatible with Windows 8.1. Therefore, please contact the developer of the theme, I can not help you here!
Problem - SFC.exe finds modified system files
After check with system file checker modified systems files are found. Why is that the case?
UltraUXThemePatcher works that way! It modifies your system files to make 3rd party themes available. If you do not wnat this, you can not use my application, sorry!Last edited by ミறѳѳղղįզվદ彡; May 13th, 2015 at 10:36 PM.
May 13th, 2015 11:42 PM #2
- Aug 2010
- Lost in the Forrest
- 303
- 298 Thread(s)
Thank You my dearest Monica............this will come in handy........
May 14th, 2015 12:00 AM #3
- 2,938
thanks றѳѳղղįqվદ much appreciated
May 14th, 2015 12:11 AM #4
Not for anything but if not just for the problems that surround this because it never works or uninstalls the way intended I have began using Big Muscles UxThemeSignatureBypass, it works great and you don't have to freak every time you do Windows Updates because there is no need to uninstall it because it doesn't modify anything that Windows needs to update.
I have experienced all three of the problems listed above at one time or another while using this and I can tell you first hand the instructions do not work , every single time I had to uninstall or make changes while using Ultra UxTheme it almost always resulted in doing a refresh or at worst case a clean install to get things back to normal, now I do not know if the problems have been addressed properly in the current version but I'm also not really interested in finding out.
The problems with this software are not addressed nearly quick enough, they are the same problems that were there when Windows 8 was released and now we are on the verge of Windows 10 being released and he just decides to address those problems now? NAH, Big Muscle is onto something that works MUCH better.
I've been using Big Muscles UxThemeSignatureBypass for a few months now and have had ZERO problems, even when installing Windows Updates.Last edited by Dark Knight; May 14th, 2015 at 12:23 AM.
May 14th, 2015 12:30 AM #5
- Jul 2011
- Nowhere
- 947
- 10 Thread(s)
I haven't tried Big Muscle's software yet (is it free, or does it watermark your desktop pending 'donations' like his Aero Glass?), but I've been using UXTheme Multi-patcher for over a year now and have had no problems. Unlike UltraUX, it merely runs as a service.....no black screens, no crashes, no BSODs. I had major issues when I used UltraUX, before I started using UXTheme Multi-patcher.
Since I'm not a big fan of BM's stuff, I think I'll stick with UXTheme Multi-patcher. It's here: https://www.windowsxlive.net/uxtheme-multi-patcher/Last edited by YourNumbr1Fan; May 14th, 2015 at 12:42 AM.
May 14th, 2015 01:53 AM #6Thank you Moon for the post. Probably a dumb question, but should i restore files changed by universal theme patcher and uninstall theme resource changer before installing this? I'm sure it's a must but asking anyway. Thanks to all!
UltraUXThemePatcher v3.6.3 20H1
By ミறѳѳղղįզվદ彡 in forum Theme PatchersReplies: 0Last Post: October 20th, 2019, 04:32 PM -
UltraUXThemePatcher 3.6.0
By dhjohns in forum General Windows 10 CustomizationReplies: 2Last Post: April 13th, 2019, 08:27 AM -
Cannot uninstall ultrauxthemepatcher, help!
By TheOriginal in forum Help and SupportReplies: 8Last Post: February 17th, 2016, 03:11 PM -
UltraUxThemePatcher 2.5.13
By ミறѳѳղղįզվદ彡 in forum Theme PatchersReplies: 0Last Post: June 27th, 2015, 10:03 PM -
UltraUXThemePatcher
By razorsedge in forum Customization ToolsReplies: 0Last Post: December 6th, 2012, 11:26 PM
Ok thanks so much ;)
Progress bar
