Results 1 to 6 of 13
August 4th, 2015 01:32 AM #1
- 1,915
Need help with my SADES Headset driver.
Hello,
I'm trying to install my SADES 7.1 Surround Sound Gaming Headset onto my comp, but it appears it doesn't support Windows 10... Is there any possible way to install it via compatibility mode (or did Microsoft pull a dumb-ass move and remove compatibility mode all together)? Any help would be much appreciated.
August 4th, 2015 11:42 AM #2
- 2,935
Darkwater409 first if it worked under 8.1 it should work under 10. second you can try rightclicking the installer, properties, compatibility, windows 7, apply, exit, then try installing. lastly this is a better question for tenforums.
August 4th, 2015 06:24 PM #3
- 1,915
August 4th, 2015 08:59 PM #4
- 2,935
rightclick the installer, properties, compatibility, check the box for run this program in compatibility mode for, use the dropdown menu to select win 7, click apply, ok. now try to run it.
August 5th, 2015 02:40 AM #5
- 1,915
I found out how to use compatibility mode on Windows 10 but apparently this driver only works on Windowss XP through to Windows 8.1. And compatibility mode doesn't seem to change that any. I messaged the SADES forums to see if there is or will be an updated driver for my model headset and am currently awaiting a response.
August 5th, 2015 11:44 AM #6
- 2,935
try switching usb ports. i know it's an old problem, but sometimes a usb device will work on one port and not another. if that doesn't work i'm out of ideas.
Driver Fusion (Driver Sweeper) silent installer
By razorsedge in forum Driver relatedReplies: 5Last Post: October 10th, 2011, 12:24 AM
Hi If possible, thanks so much
Customize icon
