September 27th, 2015 05:57 PM #1
- Nov 2013
- PerĂº
- 821
- 62 Thread(s)
Error With UXStyle or UltraUXThemePatcher (Solution)
A new problem with the famous "Windows 10"
Suddenly you have an AMD card instalastes your OS from 0, instalastes all parchastes to use third-party themes, and turn your pc reboot and you get a message like this ↓↓↓
"No AMD graphics driver installed." or
"No AMD graphics driver installed or AMD driver does not work properly."
The problem has nothing to do with your video card or the "Ux Style or" UltraUXThemePatcher "
The problem is with an update of Windows 10
After searching for nearly three hours in different forums and test solutions to exhaustion, I finally find ↓↓↓
1 Download this (at the end of post) ↓↓
2) open run it as an administrator or as normal
3) Next
4) followed by a list of updates is displayed
5) choose "hide or show updates"
(in this case select hide)
6) check that mention your video card model(in my case because I do not hide it appears)
(if you do not know which mark, I would recommend that you mark all so you make sure)
7) Next and close.
important
1 recommend that you reinstall your OS first before applying this solution
2 Install the corresponding driver ↓↓↓ (Driver AMD)
https://support.amd.com/es-xl/downloa...indows+10+-+64
3) Now if you can apply the solution
If I served as the help you said was
UxStyle
By razorsedge in forum Customization ToolsReplies: 0Last Post: September 30th, 2015, 03:36 PM -
Low Resolution Desktop Wallpaper problem solution.
By Black_knight in forum General DiscussionReplies: 1Last Post: June 20th, 2012, 12:19 PM -
Troubleshoot Volume Activation error codes and error message
By razorsedge in forum News & ReviewsReplies: 0Last Post: March 1st, 2011, 06:29 AM -
Sorry uxStyle error
By shotgun11 in forum SoftwareReplies: 3Last Post: April 24th, 2010, 01:27 PM
Miscellaneous Music...
