December 1st, 2015 04:56 PM #1
Poison Windows 10 TH2 AKA 1511 AKA 10586 Only!!
Poison
For November Update only!! TH2
Here it is again, the theme that just wont die, sadly not as good this time with the limited customization on 10 but I did the best I could, there is a Taskbar image included to use with Taskbar Color Effects.
Enjoy
StartIsBack ++1.2
- Minor changes:
UxStyle
Not fully supported on TH2
Equinox Windows 10 TH2 AKA 1511 AKA 10586 Only!!
By Mr GRiM in forum Themes by Mr GRiMReplies: 5Last Post: April 9th, 2016, 07:06 AM -
CaseLabs Windows 10 TH2 AKA 1511 AKA 10586 Only!!
By Mr GRiM in forum Themes by Mr GRiMReplies: 2Last Post: March 24th, 2016, 11:50 AM -
Meld for Windows 10 TH2 AKA 1511 AKA 10586
By gsw953 in forum Themes by gsw953Replies: 12Last Post: March 23rd, 2016, 12:44 AM -
By Mr GRiM in forum Themes by Mr GRiMReplies: 3Last Post: March 6th, 2016, 08:38 AM
Aegis Windows 11 Port...
