Results 1 to 3 of 3
Thread: How To Change Icons in Navigation Pane Windows 10
    Agelyk is offline
    Manchester United ♥
    Nov 2013
    Perú
    821
    62 Thread(s)
    I made this post because I think most people, when you apply a pack of icons (installable or theme iPack) generally change all icons except 2 icons are (Quick Access and the onedrive).
    Looking found a solution by alexgal23:
    1. When you have created the respective icons rename them (Quick Access.ico and OneDrive.ico) respectively, and paste them in C: \ PerfLogs
    2. Copy text (Keep it for later pasting, if it does not show where it says "select the registry key")
    if u SO is x86:
    HKEY_CLASSES_ROOT\CLSID\{679f85cb-0220-4080-b29b-5540cc05aab6}\DefaultIcon
    if u SO is x64:
    3. Run RegOwnershipEx.exe (x86 or x64)
    4. Click Take Ownership (x86 or x64 depending on your SO)
    5. Use the reg file to change new icons:
    OneDrive-New.reg and Quick Access-New.reg
    6 To restore default:
    OneDrive-Default.reg and Quick Access-Default.reg
    how_to_change_icons_in_navigation_pane_w10_by_alexgal23-d9jz8e1.rar
    All thanks to alexgal23for the solution
  1. Move an entry in the navigation pane (This PC)
    By tistou77 in forum General Windows 10 Customization
    Last Post: September 28th, 2020, 05:51 PM
  2. How to set text in the navigation pane to upppercase
    By Darknurgent in forum General Windows 10 Customization
    Last Post: October 20th, 2018, 12:35 AM
  3. Windows 7 Navigation Pane Customizer by kanish Bagarica
    Last Post: September 28th, 2011, 07:53 AM
  4. How to put an image in the navigation pane?
    By vagojuan in forum Explorer and shell
    Last Post: April 24th, 2011, 12:24 AM
  5. navigation pane
    By osman_2626 in forum Explorer and shell
    Last Post: February 28th, 2010, 11:55 AM
