February 2nd, 2016 07:31 PM #1
- Oct 2011
- us
- 22
- 26 Thread(s)
UXThemePatcher For Windows 10 Version 1511, 10586
This uxtheme patcher is easy and auto so you just need to download and install it, then restart your OS and enjoy new themes!
Here is the UXThemePatcher For Windows 10 November Update 10586 aka 1511 also known as TH2 Release or Autumn Update:
Support: Windows 10 November Update Version 1511, 10586 ,10586.35 ,10586.36 ,10586.71 – Windows 10 RTM Version 10240
Download
This patcher is not going make older themes work on TH2 nor will TH2 themes work on RS1, doing so will result in a white flashing screen and will require restoring or reinstalling your OS.
Windows 10 RTM, TH2 and RS1 all require themes made on those specific builds, there is no possible way to use any themes from other major builds.
This patching method is exactly the same as the Cleodesktop patching method but now comes with an installer, it does not patch the files from Th2 it is using the patched files from the RTM build.
RS1 doesn't have the same problems as Th2, patchers should work again properly and Uxstyle also works perfectly again.Last edited by Mr GRiM; February 5th, 2016 at 06:22 PM.
Windows 10 Build 10586.494 UxThemePatcher is Broken
By Shemhamforash in forum General Windows 10 CustomizationReplies: 32Last Post: July 20th, 2016, 02:52 AM -
By Mr GRiM in forum Themes by Mr GRiMReplies: 3Last Post: March 6th, 2016, 08:38 AM -
Requested Yellow for Windows !0 TH2-version 1511-10586 only
By gsw953 in forum Themes by gsw953Replies: 5Last Post: December 31st, 2015, 02:44 PM
It depends on your taste and what you actually want to achieve. There are no normal tools for this. All you can use are "workarounds" What I did is, I installed Windows 7 Segoe UI Semibold on Win...
Font rendering issue
