Results 151 to 156 of 183
February 11th, 2016 04:45 AM #1
OK I would like to share some custom import scripts I have made for importing themes from Windows 7, Windows 8 and from Windows 10 to TH2 and RS1
This is a bit more complicated in some ways but once you get the hang of it it becomes very easy.
First thing to do is select the appropriate Windows Style Builder, there are 3 different folders for TH2 and RS1, each one has a specific import script.
Windows 7 to Windows 10 TH2 (Only for TH2, does not work on RS1).
2. Open the WSB Program.
3. Go to File > Open > Import 7 Theme
4. Open the the Windows 7 Theme you want to import.
5. Save your theme and then reopen it, then save it once more and your done.
Windows 8 to Windows 10 TH2.
1. Open the folder called "Windows Style Builder 8-10 TH2"
4. Open the the Windows 8 Theme you want to import and do not save.
5. Select Import Style Hack and select "10 TH2 Import Fix" (Very important!!, will have white flashing screen if this step is missed)
6. Save your theme and then reopen it, then save it once more and your done.
Windows 10 RTM to Windows 10 TH2
1. Open the folder called "Windows Style Builder 10-10 TH2"
4. Open the the Windows 10 Theme you want to import and do not save.
For Redstone 1 it's pretty much exactly the same but this time I was not able to import a Windows 7 theme so this explanation will be skipped.
Windows 8 to Windows 10 RS1
1. Open the folder called "Windows Style Builder 8-10 RS1"
5. Select Import Style Hack and select "10 Import Fix" (Very important!!, will have white flashing screen if this step is missed)
Windows 10 RTM or TH2 to Windows 10 RS1
1. Open the folder called "Windows Style Builder 10-10 RS1"
So that's it, not too hard, of course not everything can be imported to Windows 10 but most of it can be, this will also automatically add back any missing classes that are removed and restore support for the Start menu and Taskbar so it will work with StartIsBack.
InformationUpdate March 21st 2016: Fixed a bug with importing Windows 7 themes, Some of the DWM Windows 10 Captions were messed up and not importing in the correct order.
WARNINGI am not responsible for anyone who bricks their system using these import scripts, always create a restore point, it's always best to experiment on a Virtual Machine before using on your live OS Last edited by Mr GRiM; March 21st, 2016 at 12:54 AM.
Custom Class Maps for WSB 1.5.5.6
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 23Last Post: March 22nd, 2021, 10:41 AM -
Custom Class maps & import scripts for Windows 10 RS1+ Version 1607 - 1703
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 39Last Post: March 7th, 2018, 06:46 PM -
Custom Import Scripts Import for Windows 7/8.1?
By Shemhamforash in forum Miscellaneous questionsReplies: 12Last Post: May 9th, 2016, 02:49 PM -
Custom Class Maps and Class Groups for Windows 10
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 4Last Post: August 17th, 2015, 11:55 AM
DWMBlurGlass App for...
