June 18th, 2024 02:52 PM #7
- Jun 2024
- Earth
- 14
******* hell I just lost the reply I was typing. This is the number one reason I write my shit on notepad or word and just copy-paste to the browser, sigh.
Anyway, can you use some punctuation so your instructions are less confusing? Thanks.
We already have a problem on this first step. Doing this killed 68 images and made the msstyles file corrupt. MsstyleEditor refuses to work with it.
after open theme again and save close out
after open the th2 1903 wsb press import and import the theme you did
after apply the 1903 stylehack and save theme then close and try applying the theme
Now, the instructions for converting 10 TH2 to 10 RS1 say to press "Import Win7 theme" even though it's not a Win7 theme anymore, so this contradicts my assumption to press Open rather than Win7 earlier but I'll never know without you clarifying.
1. Open the folder called "Windows Style Builder 10-10 RS1"
2. Open the WSB Program.
3. Go to File > Open > Import 7 Theme
4. Open the the Windows 10 Theme you want to import and do not save.
5. Select Import Style Hack and select "10 Import Fix" (Very important!!, will have white flashing screen if this step is missed)
6. Save your theme and then reopen it, then save it once more and your done.
Step 6 killed 22 more images. And after all that:
Code:[Window Title]Windows Style Builder [Main Instruction] Error Testing MsStyles File [Content] There was an error applying the Test MsStyles File, this usually signals an error in the MsStyles file. [Ok]
There are currently 3 users browsing this thread. (0 members and 3 guests)
Windows 10 RS6 1903 Updated Class Maps and Import script for Light Mode
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 34Last Post: April 25th, 2022, 01:42 PM -
Custom Class Maps for WSB 1.5.5.6
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 23Last Post: March 22nd, 2021, 10:41 AM -
Custom Class maps & import scripts for Windows 10 RS1+ Version 1607 - 1703
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 39Last Post: March 7th, 2018, 06:46 PM -
Custom Import Scripts Import for Windows 7/8.1?
By Shemhamforash in forum Miscellaneous questionsReplies: 12Last Post: May 9th, 2016, 02:49 PM -
Custom Class Maps and Class Groups for Windows 10
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 4Last Post: August 17th, 2015, 11:55 AM
I don't use T2 (due to the problems encountered) to see if it is updated Ok, and it also has the "use classical drive grouping" option ? You told me you didn't do it Thanks
TASKBAR2 ALPHA
