June 18th, 2024 06:42 PM #8
hi yeah when you use the wsb dont press open you need to press import after you pressed import go to save then open the theme again and press save this is using the the Windows Style Builder 7-10 TH2 this is the first wsb you need to use next you need to use Windows Style Builder TH2 - 19H1 1903. when you open this 1 dont press open go to import and find the theme you just saved after you pressed import you need to go to apply stylehack you need to apply the 1903 stylehack then save the theme after that close out hopefully it should work
Windows 10 RS6 1903 Updated Class Maps and Import script for Light Mode
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 34Last Post: April 25th, 2022, 01:42 PM -
Custom Class Maps for WSB 1.5.5.6
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 23Last Post: March 22nd, 2021, 10:41 AM -
Custom Class maps & import scripts for Windows 10 RS1+ Version 1607 - 1703
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 39Last Post: March 7th, 2018, 06:46 PM -
Custom Import Scripts Import for Windows 7/8.1?
By Shemhamforash in forum Miscellaneous questionsReplies: 12Last Post: May 9th, 2016, 02:49 PM -
Custom Class Maps and Class Groups for Windows 10
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 4Last Post: August 17th, 2015, 11:55 AM
Same problem with 22h2 / 23h2 and thumbnails ;) I have no problems with the theme and SAB, apart from those indicated with SAB T2 And my little theme is based on Windows 11 :) I always use ONE...
TASKBAR2 ALPHA
