August 7th, 2016 07:22 AM #1
- 12
- 0 Thread(s)
Mr. Grim theme: Equinox - please some help trying to find values in WSB
Hi everybody.
I taken the Equinox theme of Mr. Grim for Windows 10 TH2 to try make it darker with Windows Style Builder. All the work is almost done, just I'm missing the location of the proper values to change the colors of these annonying things:
1. The background color of the Explorer's Command bar (or whatever it is)
The value is documented in a known WSB tutorial for Windows 7 themes, however the same location doesn't exists for a Windows 10 theme, so I'm lost.
Anyways I touched and modified all the possible values in th "CommandBar -> Background" classes in WSB with no luck.
2. This grey line/border at the bottom of the Windows taskbar:
I just want to remove that, or change it to a dark color. I don't have idea where is the value to change that in WSB.
3. Seach-bar glyph:
I would like to find those four dots to replace them with a image resource of the magnifying glass image like it is on the Windows 10's default Aero theme.
EDIT:
4. Application's toolbar text-color
I noticed something is wrong with the toolbar of the applications, the menu labels are totally black, I can't see the text:
This doesn't happens with other dark themes as you can see:
...so I just need to find the value to modify the label color.
Thanks for read!Last edited by pitoloko; August 7th, 2016 at 08:49 AM.
Equinox for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 0Last Post: August 20th, 2019, 08:42 PM -
Equinox and Equinox Blackout by Mr GRiM
By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiMReplies: 8Last Post: June 14th, 2019, 04:57 PM -
Equinox and Equinox Blackout for 1903 by Mr GRiM
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 0Last Post: May 27th, 2019, 04:05 PM -
Equinox: Limited Edition Windows 8.1.1 Theme
By Lamia in forum Mr GRiM's Windows 8 ThemesReplies: 30Last Post: October 11th, 2018, 10:40 PM -
Theme wont change from Equinox
By Jaysp656 in forum Help and SupportReplies: 0Last Post: May 24th, 2013, 04:27 AM
