August 28th, 2016 09:00 PM #1
- 1,918
HUD Machine Purple for Windows 8.1
HUD Machine Purple
custom cursors
explorer frame images
image res icons
shell32 images
start buttons
wallpapers
Theme Extras
Genuine Image
Shellbrd Orb
System Clocks
HUD Machine Purple iPack
Theme Credits
Mr GRiM
Method to Install Custom Themes
How to install and setup your customization applications on Windows 8.1.1
Tools You May Need
Uxstyle, Theme Signature Bypass and UltraUxThemePatcher v3.1.0
UxStyle is a bit of software that relaxes Windows theme signature requirements to enable third-party customization. Specifically, UxStyle consists of a tiny system service and a kernel driver that are loaded into memory where they hang out until reboot. No file system changes are made. (First introduced on March 19, 2009.) UxStyle was recently rebranded to UxStyle Community Edition and published to GitHub under the GPL license.
UltraUXThemePatcher modifies your system files so that 3. party themes can be used. The program backs up the original system files and all changes can be undone by uninstalling if you have issues. UltraUXThemePatcher is available for Windows XP to Windows 10 RTM and Anniversary Update 1607 for 32bit and 64bit version. Note: This application makes changes to your system files, this can lead to unexpected problems or total breakdown of Windows!
- Restore devices / drives grouping - Everything is 'Devices and drives'. That's stupid! O-N-E can restore grouping which made sense in Win7/8.
- Restore libraries / remove folders - Remove all those folders which were unoptionally added into Windows 8.1 This PC folder and put the libraries back to their place, without registry hacking / breaking apps.
- Restore command bar / remove Ribbon - Because some people consider it an abomination.
- Restore details pane at bottom - Same reason; reclaim useful horizontal space.
- Improve styling - Get rid of some Win7 stuff here and there; improve styling with some built-in visual styles.
- For themers / skinners, O-N-E can help to override a lot of hardcoded styling in Windows 10!
For best results use these settings.
StartIsBack+ for Windows 8.1
What's cool in StartIsBack+? Start menu:
- Start menu has been rebuilt from ground up. Lot of Windows 7 menu bugs were fixed
- Items in right pane can be removed or tweaked in-place (hold shift with right-click)
- Items in right pane can be configured as menu for more items (like Connect To)
- You can add your own folders into right pane by drag & drop
- All Programs can show folders before items
- Start menu configuration is much more streamlined
Start button:
- StartIsBack+ provides start button for each taskbar
- StartIsBack+ uses built-in Windows 8.1 start button image (by default), but with different selection / animation effect to distinguish it
- This utility returns the complete glass effect into windows frames.
- Apply glass look to windows borders
- Improve UI experience
- Change amount of transparency in Control panels directly
- Change inactive windows borders color
- Skin windows borders (add glow, shadows etc.) without changing Windows theme
- Fully native including MSStyle themes and DWM API compatibility
- Low resources usage
After years of development, Winaero Tweaker is an all-in-one application which will include most options available in the free Winaero apps and extend it as much as possible. It is a universal tweaker software which supports Windows 7, Windows 8, Windows 8.1 and Windows 10.
- Create a Restore Point
- Install Fonts included in the "Extras" folder
- Apply System Metrics included in the "Extras" folder and logout or reboot
- Copy a Start Orb from the "Theme" folder to a new location, rename it if it's 6801, 6805, or 6809, open the StartIsBack+ configuration, click Add... select the Start Orb and Start Menu and click Apply.
- If it's not a visible option to select the themed start menu, apply your custom theme first!
- Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
August 28th, 2016 10:56 PM #2
Looks great bud, I am looking at out text color now on the dark style and it seems to be a bit dark and hard to read in places, just been messing with some alternatives and I am thinking this might be better instead of rgb 98, 83, 172 change it to 130, 115, 220 that text color looks a bit bright on the clock though so for that I went with rgb 105, 85, 210 just thinking the text needed a bit more contrast, everything else though looks awesome.
August 28th, 2016 11:21 PM #3
- 1,918
Thank you, I can work on implementing that text color change soon. The dark slate theme also has most of its images with the black matte not removed other than the ones you linked that needed replacing, not sure if that theme may need an update as well, I think you changed some text in that one that looked slightly purple at least in the start menu, I may have a look at the theme for RS1 and see what differences I can find
August 29th, 2016 02:51 AM #4
- Oct 2012
- Virtual Customs
- 1,672
- 337 Thread(s)
Thanks mate for recoloring, also i want to mention to fix start menu search bug you have in dark theme go here:
Start Menu > Panels > Aero > Top > Programs List > Panels > Programs List - and change ALPHATRASHOLD to 0
I already change text color style to Mr GRiM suggestion and kinda like it more that way, overall everything looks great and thank you for sharing it!If you like theme's & material's from Artist, give them support by reputation!
August 29th, 2016 03:24 AM #5
- 1,918
August 29th, 2016 04:29 AM #6
- 1,918
Updated theme for dark style system-wide text color change
HUD Machine Purple Ultimate edition for Windows 10 20h1 20h2
By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiMReplies: 0Last Post: February 9th, 2021, 01:49 PM -
HUD Machine Purple for Windows 10 Creators Update
By Mr GRiM in forum Themes by Mr GRiMReplies: 7Last Post: January 30th, 2018, 05:56 AM -
Windows 10 Purple Request
By Nephoros in forum Requests, Site Problems and FeedbackReplies: 6Last Post: January 28th, 2018, 06:09 AM -
HUD Machine Purple for Windows 10 Anniversary Update Redstone 1
By Mr GRiM in forum Themes by Mr GRiMReplies: 2Last Post: August 30th, 2016, 04:33 PM -
hud for windows 8 in a purple
By polterghozt in forum Theme RequestsReplies: 0Last Post: May 30th, 2013, 12:21 PM
Aegis Windows 11 Port...
