April 26th, 2017 03:11 PM #1
Poison For Windows 10 1703 - 1903
Poison
For Windows 10 1703 - 1903 (RS2 THRU RS6 )
Poison
Original Theme By Mr GRiM - Port by Dark Knight
custom cursors
shell32 images
start button
wallpapers
Theme Extras
Shellbrd Orb
Theme Credits
Mr GRiM - custom import scripts & Original Theme Design
ThemeSignatureBypass by Big Muscle
Installing themes on Windows 10:
Some Tools You May Need
Modern icon glyphs on Start menu right hand pane
Fully dynamic DPI aware start menu and configuration app
New modern style with round user picture
Lots of new minor additions and tweaks
Recommended Prior to Applying Custom Themes:
1.) Create a Restore Point
2.) Install Fonts included in the "Extras" folder
3.) Apply System Metrics included in the "Extras" folder and logout or reboot
4.) Install an iPack of your choice to change the system icons
5.) Select the Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first!
6.) Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
I take no responsibility for anyone that bricks their system, use custom themes at your own risk
WARNINGPlease make sure you download the correct theme file according to your Windows version!
April 29th, 2017 10:31 PM #7
You did not do something right .........
In order to have the taskbar and start menu display you must select them in the StartIsBack properties, assuming you have StartIsBack++ installed, open the start menu and right click on a blank area and select "Properties", under the Appearance menu select the start menu, taskbar and start orb you want to use. Under the Start Menu Tab, make sure "Display Gyph Icons" is deselected.
As far as theme borders not showing, I told you that you must double click the .theme file from within Windows Explorer at C:\Windows\Themes\Resources, before you do this make sure you revert back to the Windows default theme.
April 30th, 2017 07:04 PM #8
- Jan 2015
- in my home
- 7
Thanks for the help but although I did all these yet again from the start for some reason it doesn't work for me. I only need Themesignaturebypass, oldnewexplorer and startisback++ right??? and the theme also I mean.
June 21st, 2018 03:30 PM #9
- Nov 2017
- Australia
- 1,328
- 11 Thread(s)
Thanks a Bunch Dark Night, This is Exellent nice work Keep'em Coming Bro. Cheerz
November 12th, 2018 02:27 AM #10
Thread has been updated to include theme port for Windows 10 RS5 (1809)
November 12th, 2018 03:43 AM #11
- Nov 2017
- Australia
- 1,328
- 11 Thread(s)
Thanks for the updates Dark Knight its really Cool the way you Guyz have been updating all my Favz, I love this one its one of my first I installed on 1709 now 1809 Wow we have come a long way in the last 12Months Thanks Again for all your Great Workz Bro Cheerz !!!
June 2nd, 2019 08:22 AM #12
Thread has been updated, now includes theme download for Windows 10 Spring 2019 Update 1903 [RS6]
Poison Version 2 for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 5Last Post: August 24th, 2019, 01:56 PM -
Heavy Docker for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 11Last Post: June 7th, 2019, 06:25 PM -
Teek Modern for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 5Last Post: June 5th, 2019, 03:09 PM -
Sufferance Blue for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 4Last Post: June 4th, 2019, 02:57 PM -
Airlock for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 13Last Post: May 29th, 2019, 05:15 AM
This is my rig. I'm currently in the process of getting it upgraded. (Don't mind the messy room, I'm poor asf so I live in a dump, lmao) Current Specs Model: Dell Optiplex 755
Show Us Your Rig
