May 18th, 2017 06:08 PM #1
Airlock for Windows 10 1703 - 1903
Airlock
For
Windows 10 1703 - 1803 (RS2 THRU RS4 )
Windows 10 Fall 2018 Creators Update 1809 (RS5)
Windows 10 Spring 2019 Creators Update (RS6)
Airlock
Original Theme By Gor - Port by Dark Knight
custom cursors
shell32 images
start button
wallpapers
Theme Extras
Shellbrd Orb
Theme Credits
Mr GRiM - custom import scripts
Gor - Original Theme Design
ThemeSignatureBypass by Big Muscle
NOTEI made one small change to the theme and that is the aero peek Window, only because the original just didn't look right.
Installing themes on Windows 10:
Some Tools You May Need
ONE (OldNewExplorer - Included in download in Extras folder)
StartIsBack++ for Windows 10 (included with download in extras folder)
Modern icon glyphs on Start menu right hand pane
Fully dynamic DPI aware start menu and configuration app
New modern style with round user picture
Lots of new minor additions and tweaks
Recommended Prior to Applying Custom Themes:
1.) Create a Restore Point
2.) Install Fonts included in the "Extras" folder
3.) Apply System Metrics included in the "Extras" folder and logout or reboot
4.) Install an iPack of your choice to change the system icons
5.) Select the Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first!
6.) Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
I take no responsibility for anyone that bricks their system, use custom themes at your own risk
Poison Version 2 for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 5Last Post: August 24th, 2019, 01:56 PM -
Poison For Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 16Last Post: June 28th, 2019, 05:11 PM -
Heavy Docker for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 11Last Post: June 7th, 2019, 06:25 PM -
Teek Modern for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 5Last Post: June 5th, 2019, 03:09 PM -
Sufferance Blue for Windows 10 1703 - 1903
By Dark Knight in forum Themes by Dark KnightReplies: 4Last Post: June 4th, 2019, 02:57 PM
Aegis Windows 11 Port...
