May 26th, 2017 06:20 AM #1
- Aug 2011
- Atlanta, Georgia
- 1,575
- 280 Thread(s)
Diablo Reaper Of Souls for Windows 10 1703 - 1803 and 1903
and
Windows 10 Spring 2019 Update 1903 RS6 [19H1]
start button
11 wallpapers
Adobe Splash Screens
RocketDock Skin
RocketDock Icons
Matching Screensaver
Some Tools You May Need
ONE
1.) Create a Restore Point
If you are new to installing custom themes or might be having issues, please read my thread here: Tools needed to install and run custom themes
WARNINGMake sure you download the correct theme file according to your Windows version!
Diablo Reaper of Souls Special Porters Edition for Windows 10 19H1 ONLY
By Dark Knight in forum Themes by Dark KnightReplies: 9Last Post: June 12th, 2019, 04:11 PM -
Diablo Reaper of Souls for Windows 10 TH2 Aka 1511
By freak69ize in forum Themes by Freak69izeReplies: 10Last Post: April 29th, 2016, 08:06 PM -
Diablo Reaper of Souls iPack Request
By Nimbi in forum RequestsReplies: 2Last Post: April 26th, 2016, 02:15 AM -
By razorsedge in forum Razorsedge Windows 7 ThemesReplies: 22Last Post: March 31st, 2016, 07:21 PM -
Diablo: Reaper Of Souls Windows 8.1.1 Theme
By Lamia in forum Razorsedge windows 8 ThemesReplies: 11Last Post: October 28th, 2014, 06:59 PM
