Results 1 to 6 of 10
Thread: Diablo Reaper Of Souls for Windows 10 1703 - 1803 and 1903
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    1,571
    280 Thread(s)
    and
    Windows 10 Spring 2019 Update 1903
    RS6 [19H1]
    start button
    11 wallpapers
    Adobe Splash Screens
    RocketDock Skin
    RocketDock Icons
    Matching Screensaver
    Some Tools You May Need
    ONE
    1.) Create a Restore Point
    If you are new to installing custom themes or might be having issues, please read my thread here: Tools needed to install and run custom themes
    Make sure you download the correct theme file according to your Windows version!
  1. Diablo Reaper of Souls Special Porters Edition for Windows 10 19H1 ONLY
    Last Post: June 12th, 2019, 04:11 PM
  2. Diablo Reaper of Souls for Windows 10 TH2 Aka 1511
    By freak69ize in forum Themes by Freak69ize
    Last Post: April 29th, 2016, 08:06 PM
  3. Diablo Reaper of Souls iPack Request
    By Nimbi in forum Requests
    Last Post: April 26th, 2016, 02:15 AM
  4. Diablo Reaper of Souls
    Last Post: March 31st, 2016, 07:21 PM
  5. Diablo: Reaper Of Souls Windows 8.1.1 Theme
    By Lamia in forum Razorsedge windows 8 Themes
    Last Post: October 28th, 2014, 06:59 PM
