Results 13 to 18 of 18
May 31st, 2017 03:15 AM #1
HUD Evolution for Windows 10 Creators Update AKA RS2 AKA 1703
HUD Evolution
Original Theme By Mr GRiM - Port to Creators Update by Dark Knight
custom cursors
shell32 images
start button
5 Different Wallpapers
Theme Extras
Shellbrd Orb
Aimp skin
Theme Credits
Mr GRiM - custom import scripts
Mr GRiM - Original Theme Design
ThemeSignatureBypass by Big Muscle
Installing themes on Windows 10:
Some Tools You May Need
ONE
Modern icon glyphs on Start menu right hand pane
Fully dynamic DPI aware start menu and configuration app
New modern style with round user picture
Lots of new minor additions and tweaks
Recommended Prior to Applying Custom Themes:
1.) Create a Restore Point
2.) Install Fonts included in the "Extras" folder
3.) Apply System Metrics included in the "Extras" folder and logout or reboot
4.) Install an iPack of your choice to change the system icons
5.) Select the Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first!
6.) Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
I take no responsibility for anyone that bricks their system, use custom themes at your own risk
August 25th, 2018 04:48 AM #13
this theme works on april update ?(1803)
August 25th, 2018 09:36 AM #14
- Jul 2012
- pisa
- 333
- 325 Thread(s)
August 28th, 2018 04:23 PM #15ok thanks
November 4th, 2018 08:30 AM #16
- Apr 2014
- Greece
- 2
Hello, just done the core install with fonts, startisback and everything with the theme but I have a little problem. No sounds play when my laptop starts up and shuts down. I've checked on the theme's properties and the sounds are there and checked to work when doing so.
I use 10 on April's update (1803) as someone already asked before me if they work and I have a Lenovo laptop. Did a new format only for this. Had the same theme on my last laptop on W7 Ultimate and everything worked fine
November 4th, 2018 06:24 PM #17
I don't think this is a theme issue, switch your Windows theme to the default Windows 10 theme then restart, do you get startup or shutdown sounds? I don't.
This is more than likely a Windows 10 thing, if memory serves correctly, I don't remember having any startup or shutdown sounds since Windows 7. It may have something to do with fast startup, try disabling and see if that works.
November 5th, 2018 11:07 AM #18
- Apr 2014
- Greece
- 2
Adiccion X for Windows 10 Creators Update AKA RS2 AKA 1703
By Agelyk in forum Themes by angel960Replies: 9Last Post: October 4th, 2018, 06:05 PM -
KTZ - for Windows 10 Creators Update AKA RS2 AKA 1703
By niivu in forum Themes by niivuReplies: 0Last Post: May 25th, 2017, 12:58 AM -
ATF for Windows 10 Creators Update AKA RS2 AKA 1703
By niivu in forum Themes by niivuReplies: 3Last Post: May 18th, 2017, 06:13 PM -
Papyros for Windows 10 Creators Update AKA RS2 AKA 1703
By niivu in forum Themes by niivuReplies: 6Last Post: May 8th, 2017, 10:19 AM -
BIB for Windows 10 Creators Update AKA RS2 AKA 1703
By niivu in forum Themes by niivuReplies: 2Last Post: May 3rd, 2017, 11:44 PM
Aegis Windows 11 Port...
