June 15th, 2017 02:04 AM #1
- Aug 2014
- Ontario, Canada
- 1,914
- 167 Thread(s)
Alienware HQ Red for Windows 10 Creators - April 2018 Update
Alienware HQ Red for Windows 10 Creators - April 2018 UpdateUxstyle, Theme Signature Bypass and UltraUxThemePatcher
Alienware HQ Red
start button
Genuine Image
Original theme by designfjotten
Imported and modified by Shemhamforash
Theme Changelog
Rebuilt borders and caption buttons for Windows 10 style caption buttons
Added date, immersive context menus and new SiB++ taskbar skinning - modded taskbar thumbnail mouse over preview window
Made various fixes from the Windows 8.1 theme - fixed start search content margins, modded aero snap, modded copy/close/pause images
Added compatibility for using the theme without Aero Glass
Tools You May Need
Alienware HQ Gold for Windows 10 Creators - April 2018 Update
By Shemhamforash in forum Themes by ShemhamforashReplies: 4Last Post: September 27th, 2020, 01:15 AM -
Borg for Windows 10 Creators - April 2018 Update
By Shemhamforash in forum Themes by ShemhamforashReplies: 2Last Post: May 6th, 2018, 08:37 PM -
Castle for Windows 10 Creators - April 2018 Update
By Shemhamforash in forum Themes by ShemhamforashReplies: 5Last Post: May 6th, 2018, 08:37 PM -
HUD for Windows 10 Creators - April 2018 Update
By Shemhamforash in forum Themes by ShemhamforashReplies: 26Last Post: May 6th, 2018, 08:37 PM -
Zero-G for Windows 10 Creators - April 2018 Update
By Shemhamforash in forum Themes by ShemhamforashReplies: 4Last Post: May 6th, 2018, 08:35 PM
After October 14, 2025, Microsoft will no longer provide security updates or technical support for Windows 10 - https://www.microsoft.com/en-us/windows/end-of-support?r=1
Windows 12
