Results 13 to 18 of 22
Thread: Alienware HQ Red for Windows 10 Creators - April 2018 Update
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,912
    167 Thread(s)
    Alienware HQ Red
    start button
    Genuine Image
    Original theme by designfjotten
    Imported and modified by Shemhamforash
    Theme Changelog
    Rebuilt borders and caption buttons for Windows 10 style caption buttons
    Added date, immersive context menus and new SiB++ taskbar skinning - modded taskbar thumbnail mouse over preview window
    Made various fixes from the Windows 8.1 theme - fixed start search content margins, modded aero snap, modded copy/close/pause images
    Added compatibility for using the theme without Aero Glass
    Tools You May Need
  1. Alienware HQ Gold for Windows 10 Creators - April 2018 Update
    Last Post: September 27th, 2020, 01:15 AM
  2. Borg for Windows 10 Creators - April 2018 Update
    Last Post: May 6th, 2018, 08:37 PM
  3. Castle for Windows 10 Creators - April 2018 Update
  4. HUD for Windows 10 Creators - April 2018 Update
  5. Zero-G for Windows 10 Creators - April 2018 Update
    Last Post: May 6th, 2018, 08:35 PM
