Thread: Theme by Innuendo ( Yoda San )
July 23rd, 2017 05:58 PM #1
Hi all
I wanted to share my first public theme under win 10
I couldn't thank so much my friend gsw953 to have accepted with such kindness to do the startisback skinning part to get most of people enjoying it and as I'm not as skilled as he is !
This theme is both compatible under Anniversary and Creator update but with aeroglass 1.5.3 , Anniversary update users will get the most since it wasn't updated atm for Creator update builds.
PATCH FILES
1607 users with UxStyle_0242_x86_x64_preview.exe
1703 ( Creator update ) with https://www.syssel.net/hoefs/softwar...me.php?lang=en
The archive includes :
- misc icons for nav pane and drives ( as on the top screen on my rig)
- tools ( moo0 transparent menu installer / win color to set the taskbar icons under AU with fine tune / OldnewExplorer to get rid of the native ribbon / Tbaricon blanker to make titlebar icons invisible but modern apps ( thanks to Niivu for the tip )
AeroGUI tool provided too
- the modded branding file ( basebrd.dll to use the theme branding ) for replacing the orignal one in C:\windows\branding\basebrd
- the classic shell menu skin ( thanks to Juniper from Classic shell forums for helping me finalize it like I wanted to)
- the qttabar skin
IMPORTANT NOTES:
- qttabbar users , the following is tricky to get the perfect tab transparency you have to set transparency using the native qttabbar feature .
This is the only way I found to have perfect transparent or glass tabs without any other tool
- You also need to get rid of the refresh & previous icons in adressbar with https://neiio.deviantart.com/art/Blank-It-631635180
- general transparency
AU won't have any issue with aeroglass - CU users ,I don't recommend you using aeroglass too buggy with so please get as recommended by gsw953 blend tool here :
https://devrexster.deviantart.com/art...0-0-1-76090504
- you also need to use this to get rid of previous & refresh icons in adressbar https://neiio.deviantart.com/art/Blank-It-631635180
Other credits to:
3am at WSB forums for his precious advices when I got stuck , Mr GRIM for his classes maps and his general work and help at a moment in this project .
I'm also conscious there will be some fixes and I try to update them when founded .
And thanks again to gsw953 !!
Dark Minimal Glass.zip
Dark Minimal Glass for Creator update and Startisback users here :
https://virtualcustoms.net/showthread...reators-UpdateLast edited by innuendo; July 24th, 2017 at 08:02 PM.
DMG-SiB by gsw953 and innuendo for Windows 10 19h1+
By ミறѳѳղղįզվદ彡 in forum Themes by gsw953Replies: 5Last Post: September 19th, 2020, 02:45 AM -
Properties menu unreadable (Basic Black Theme, Midnight Glass theme)
By Leon300 in forum Windows 7 Theme Help & SupportReplies: 0Last Post: June 10th, 2018, 12:06 PM -
Christmas theme by Deviantdon W10 Fall Creators Update Theme
By Erin in forum Themes by ErinReplies: 9Last Post: January 6th, 2018, 11:46 AM -
Theme issue with task bar, start menu Forced to Classic Theme, Help.
By YumiiUnami in forum Theme IssuesReplies: 18Last Post: July 10th, 2012, 07:03 PM -
Aegis Windows 11 Port...
