Results 103 to 108 of 108
Thread: Windows 10 Creators - April 2018 Update Themes Complete Collection
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,912
    167 Thread(s)
    Installation Walkthrough
    Before applying any custom theme, create a restore point.
    I recommend using Theme Signature Bypass in "files\patcher" as a theme patcher. Or try UltraUxThemePatcher instead.
    These themes rely on the correct settings of OldNewExplorer.
    Install StartIsBack++ to skin the start menu and taskbar.
    Start orbs are in "files\orbs". Select the theme's start menu and an orb in the StartIsBack++ configuration and click apply. The "files\orbs_downsized" directory contains start orbs modified to work with the small taskbar buttons setting.
    is the application for tweaking the rest of your system.
    Aero Glass can be used for additional window transparency.
    Install the fonts included in the "files\fonts" folder. Type ctrl+a then right click, click "install" with "no" and "do this for all current items" checked.
    Merge the registry tweaks in "files\rc_context_menu" so that it's possible to switch themes from the desktop right click menu.
    Merge a system metrics registry file in "files\system_metrics" so borders and fonts can be adjusted.
    I use the AltDrag app in
    "files\transparency_app" for mouse and keyboard shortcuts and window transparency.
    Logout or reboot your pc at some point.
    Cut/paste the contents of "themes" into your themes folder ("C:\Windows\Resources\Themes").
    Apply a theme via "Control Panel -> Personalization" from the desktop rc menu "Personalize (classic) -> Theme Settings".
    Theme Showcase
    Alienware HQ Gold by designfjotten:
    Imported from theme: Alienware HQ GOLD Windows 7 Theme
    AMD Experience the Revolution by Razorsedge:
    Imported from theme: Revolution: The AMD Theme Mastering Works
    Annihilation by Razorsedge:
    Imported from theme: Annihilation Mastering Works
    Annihilator by Mr GRiM:
    Imported from theme: Annihilator
    ASUS by deviantdon & one man army:
    Imported from theme: ASUS
    BadAzz Dream by deviantdon:
    Imported from theme: BadAzz Dream
    Borg by Razorsedge:
    Imported from theme: Borg Mastering Works
    By Design by Mr GRiM:
    Imported from theme: By Design
    Castle by Razorsedge:
    Imported from theme: Castle Mastering Works
    Chrononaut by Razorsedge:
    Imported from theme: Chrononaut Mastering Works
    DeathStar by Mr GRiM:
    Imported from theme: DeathStar
    Elvira by Razorsedge:
    Imported from theme: Elvira Mistress of the Dark Mastering Works
    Event Horizon by Razorsedge:
    Imported from theme: Event Horizon Dual Themes: Mastering Works
    Hardwired by Razorsedge:
    Imported from theme: Hardwired
    HUD Apocalypse by Mr GRiM:
    Imported from theme: HUD Apocalypse
    HUD Machine White by Mr GRiM:
    Imported from theme: HUD Machine White
    HUD by Mr GRiM:
    Klingon by Razorsedge:
    Imported from theme: Klingon Mastering Works
    LOTR by Razorsedge:
    Imported from theme: Lord of the Rings Middle Earth Mastering Works
    Metal Graveyard by Razorsedge:
    Imported from theme: Metal Graveyard: Rise from the Ashes Mastering Works
    MS One by Razorsedge:
    Imported from theme: Maxium Security One Mastering Works
    Nightshade by Razorsedge:
    Imported from theme: Nightshade Mastering Works
    Nvidia by Razorsedge:
    Imported from theme: Nvidia Mastering Works
    Prometheus by Razorsedge:
    Imported from theme: Prometheus Dual Themes Mastering Works
    Rockstar by Razorsedge:
    Imported from theme: Rockstar Mastering Works
    Sophistication Incorporated by Razorsedge:
    Imported from theme: Sophistication Incorporated Mastering Works
    Supernatural by Razorsedge:
    Imported from theme: Ghosts of Purgatory Mastering Works
    The Colony by Razorsedge:
    Imported from theme: The Colony Mastering Works
    Toxic Blue by Mr GRiM:
    Imported from theme: Toxic Blue
    Toxic by Mr GRiM:
    TUF Covert Ops by Razorsedge:
    Imported from theme: TUF Covert Ops Mastering Works
    Zero-G by Mr GRiM:
    Imported from theme: Zero-G
  1. ASUS Complete Collection for Windows 10 Creators - April 2018 Update
    Last Post: October 3rd, 2020, 11:57 PM
  2. Hardwired Dual Themes for Windows 10 Creators - April 2018 Update
    Last Post: May 6th, 2018, 08:37 PM
  3. MS One Dual Themes for Windows 10 Creators - April 2018 Update
    Last Post: May 6th, 2018, 08:36 PM
  4. Prometheus Dual Themes for Windows 10 Creators - April 2018 Update
