Results 7 to 12 of 13
Thread: Accretion
    devillnside is offline
    Elite
    Aug 2012
    Dhaka, Bangladesh
    1,458
    1 Post(s)
    51 Thread(s)
    Accretion
    Accretion
    Theme for Windows 7
    Updated to version 1.3
    Screenshots updated for the new version
    Changelog:
    10.09.18:
    Tweaked the Navigation buttons.
    Made the start menu inner border darker.
    Replaced the Start Buttons with a new set & fixed the alignment so that they are more centred.
    Rebuilt the DWM Top window frames.
    Rebuilt the DWM Bottom window frames and changed the sizing margins to match the Top Frames.
    Rebuilt the DWM Left & Right window frames.
    Fixed a couple of previously untouched text properties.
    Complete rebuild of the Taskbar backgrounds.
    Rebuilt the Taskband backgrounds.
    Rebuilt the Show Desktop Buttons.
    Increased Aero Peek window Reflection transparency.
    Rebuilt the System Tray background.
    Fixed Tray Notify Buttons alignment.
    Rebuilt the default wallpaper to better highlight theme features.asd
    Updated to version 1.2
    Changelog:
    04.09.18:
    Added a new set of Wallpaper variants in 1920x1080 & 2560x1440 resolutions
    Redid the DWM Bottom Frames.
    Redid the DWM Left & Right Frames.
    Fixed Browser Tab Backgrounds not fixed.
    Tweaked Taskbar Images.
    Tweaked Toolbar Background Image.
    Tweaked Details Pane Image.
    Tweaked Tray Notify Footer Image.
    Tweaked Tray Notify Header Image.
    Tweaked System Tray Link Area Image.
    Tweaked Task Dialog Secondary Panel Image.
    Tweaked Control Panel Command Area Images.
    Tweaked DWM Window Top & Bottom Frames.
    Made some more adjustments on Menu Bar, Rebar & Bar Background Images.
    Recoloured the tab pane & body images & changed the fillcolor properties again to improve text visibility some more.
    Updated to version 1.1
    Changelog:
    01.09.18:
    Fixed Start Menu All Programs margins
    Changed Addressbar dropdown glyph
    Tweaked the start button
    Tweaks the taskband images
    Tweaked the dropdown glyphs for toolbar
    Tweaked the system tray expand buttons
    Tweaked the taskitem buttons
    Fixed the margins for the right window frames
    Replaced the bottom frame images to match the top frame images
    Replaced the jump list background images
    Replaced the menu bar, rebar & bar background images.
    Recoloured the tab pane & body images & changed the fillcolor porperties to a lighter shade for better visibility.
    Added gradients to the window caption control buttons
    Changed the margins for the push buttons & tweaked the images a bit.
    Changed the colorizationcolor in the .theme file for more transparency.
    Tweaked the addressbar & searchbar images and changed the margins
    Fixed the Help window header images not themed
    How to:
    Or
    Theme Extras:
    Shellbrd.dll (Branding) Image
    System.cpl (Genuine) Image
    Timedate.cpl
    (Date & Time Clock) Image
    Accretion VS 1.3.zip
    Last edited by devillnside; September 11th, 2018 at 04:03 PM. Reason: Updated theme to version 1.3
    D@rkside Of Aquarius™
Tags for this Thread
