Thread: Accretion
August 29th, 2018 12:52 AM #1
Accretion
Accretion
Theme for Windows 7
Updated to version 1.3
Screenshots updated for the new version
10.09.18:
Tweaked the Navigation buttons.
Made the start menu inner border darker.
Replaced the Start Buttons with a new set & fixed the alignment so that they are more centred.
Rebuilt the DWM Top window frames.
Rebuilt the DWM Bottom window frames and changed the sizing margins to match the Top Frames.
Rebuilt the DWM Left & Right window frames.
Fixed a couple of previously untouched text properties.
Complete rebuild of the Taskbar backgrounds.
Rebuilt the Taskband backgrounds.
Rebuilt the Show Desktop Buttons.
Increased Aero Peek window Reflection transparency.
Rebuilt the System Tray background.
Fixed Tray Notify Buttons alignment.
Rebuilt the default wallpaper to better highlight theme features.asd
Updated to version 1.2
04.09.18:
Added a new set of Wallpaper variants in 1920x1080 & 2560x1440 resolutionsRedid the DWM Bottom Frames.
Redid the DWM Left & Right Frames.
Fixed Browser Tab Backgrounds not fixed.
Tweaked Taskbar Images.
Tweaked Toolbar Background Image.
Tweaked Details Pane Image.
Tweaked Tray Notify Footer Image.
Tweaked Tray Notify Header Image.
Tweaked System Tray Link Area Image.
Tweaked Task Dialog Secondary Panel Image.
Tweaked Control Panel Command Area Images.
Tweaked DWM Window Top & Bottom Frames.
Made some more adjustments on Menu Bar, Rebar & Bar Background Images.
Recoloured the tab pane & body images & changed the fillcolor properties again to improve text visibility some more.
Updated to version 1.1
01.09.18:Fixed the Help window header images not themed
Fixed Start Menu All Programs margins
Changed Addressbar dropdown glyph
Tweaked the start button
Tweaks the taskband images
Tweaked the dropdown glyphs for toolbar
Tweaked the system tray expand buttons
Tweaked the taskitem buttons
Fixed the margins for the right window frames
Replaced the bottom frame images to match the top frame images
Replaced the jump list background images
Replaced the menu bar, rebar & bar background images.
Recoloured the tab pane & body images & changed the fillcolor porperties to a lighter shade for better visibility.
Added gradients to the window caption control buttons
Changed the margins for the push buttons & tweaked the images a bit.
Changed the colorizationcolor in the .theme file for more transparency.
Tweaked the addressbar & searchbar images and changed the margins
How to:
You'll need your system patched with either UXTheme or UXStyle & have Theme Resource Changer installed for the theme to apply exactly like in the screen shot.
Links to UXTheme Patcher & UXStyle Core for both 32bit & 64bit systems are in the 'Links For Softwares' text file in the zip.
Links for Theme Resource Changer for both 32bit & 64bit systems also included in the text file.
All links are to my Mega Account, so they should be clean.
https://mega.nz/#F!TAYGGBCR!xa83jWcTS9TBJGbER50jrw
Download & use the ones relevant to your system.
Just extract the zip & copy the contents of the 'Theme' folder to:
'C:\Windows\Resources\Themes' & apply.
Be sure to have Theme Resource Changer installed before applying & it will take care of the rest.
A logon screen is included with the theme.
Instructions for changing the Logon Background manually is included in the Logon folder.
Or
if you prefer the easier way, there are free programs available, namely Windows logon changer, that change the logon screen background easily.
A quick google search will get you results.
Theme Extras:
Shellbrd.dll (Branding) Image
System.cpl (Genuine) Image
Timedate.cpl (Date & Time Clock) Image
& instructions on how to use them are included in the zip.
Accretion VS 1.3.zip
Last edited by devillnside; September 11th, 2018 at 04:03 PM. Reason: Updated theme to version 1.3
September 30th, 2018 09:31 AM #13
