October 7th, 2018 01:27 PM #1
Windows 10 1809 WSB update and Dark Mode Style Script
Got the import script working pretty good now, updated all the WSB class and group maps and also updated the shellstyle to take advantage of some of the new changes.
You can try these out if you like, they still don't seem to work perfectly, I was getting msstyle errors on a couple of themes but 95% of the themes I updated with the script worked fine, you will still have to eddit a couple of colors here and there though.
Main colors to edit after are as follows (Some of these are new parts that were added):
Buttons, Boxes, & Controls > Scroll Bars & Trackers > ScrollBar > FillColor (This fill color is the background behind the gripper on the open and save as windows)
Windows 10 Dark Mode > Explorer & Shell > Shell > PreviewPaneControl > CommonItemsDialog:Edit > Background (This fill color is at the bottom of the save as window behind the drop downs)
Windows 10 Dark Mode > Address, Breadcrumb, & Search > Address > ComboBox > Normal > Active > DropDownTextArea > Hot (This fill color is the drop down on the address bar)
Hold shift and click on Import Stylehack and then select "Dark Mode Import Script" then Apply Script.
Now you can reopen the saved theme and do any edits that need to be done.
All the new dark classes have been put in their own section with the same layout as the default theme, I did have to leave some parts out on the import script though as they caused to many problems, the parts were the address bar breadcrumbs and the command module, the classes have still been added to the msstyles though so feel free to see if you can get them working.
If your interested here is the import script that I had to make.
Code:<!-- Author: Mr GRiM --> <stylescript> <add> <!-- Windows 10 Dark Mode > Toolbars, Headers, & Rebar --> <class name="DarkModeNavbarComposited::Rebar"/> <class name="DarkModeInactiveNavbarComposited::Rebar"/> <class name="DarkModeMaxNavbarComposited::Rebar"/> <class name="DarkModeMaxInactiveNavbarComposited::Rebar"/> <class name="DarkModeNavbarBase::Rebar"/> <class name="DarkModeNavbarNonTopmost::Rebar"/> <class name="DarkModeNavbar::Rebar"/> <class name="DarkModeInactiveNavbar::Rebar"/> <class name="DarkModeMaxNavbar::Rebar"/> <class name="DarkModeMaxInactiveNavbar::Rebar"/> <class name="DarkMode::Toolbar"/> <class name="DarkMode_ItemsView::Header"/> <!-- Windows 10 Dark Mode > Address, Breadcrumb, & Search --> <class name="DarkMode_ABComposited::AddressBand"/> <class name="DarkMode_AddressComposited::ComboBox"/> <class name="DarkMode_InactiveAddressComposited::ComboBox"/> <class name="DarkMode_MaxAddressComposited::ComboBox"/> <class name="DarkMode_MaxInactiveAddressComposited::ComboBox"/> <class name="DarkMode_AddressComposited::Edit"/> <class name="DarkMode_InactiveAddressComposited::Edit"/> <class name="DarkMode_MaxAddressComposited::Edit"/> <class name="DarkMode_MaxInactiveAddressComposited::Edit"/> <class name="DarkMode_BBComposited::Toolbar"/> <class name="DarkMode_InactiveBBComposited::Toolbar"/> <class name="DarkMode_MaxBBComposited::Toolbar"/> <class name="DarkMode_MaxInactiveBBComposited::Toolbar"/> <class name="DarkMode::TryHarder"/> <class name="DarkMode_SearchBoxEditComposited::Edit"/> <class name="DarkMode_InactiveSearchBoxEditComposited::Edit"/> <class name="DarkMode_MaxSearchBoxEditComposited::Edit"/> <class name="DarkMode_MaxInactiveSearchBoxEditComposited::Edit"/> <class name="DarkMode_SearchBoxComposited::SearchBox"/> <class name="DarkMode_InactiveSearchBoxComposited::SearchBox"/> <class name="DarkMode_MaxSearchBoxComposited::SearchBox"/> <class name="DarkMode_MaxInactiveSearchBoxComposited::SearchBox"/> <class name="DarkMode::SearchBox"/> <!-- Windows 10 Dark Mode > Buttons, Boxes, & Controls --> <class name="Explorer::Button"/> <class name="DarkMode_Explorer::Button"/> <class name="DarkMode::Navigation"/> <class name="CFD::Combobox"/> <class name="DarkMode_CFD::Combobox"/> <class name="Explorer::ScrollBar"/> <class name="DarkMode_Explorer::ScrollBar"/> <!-- Windows 10 Dark Mode > Lists, Menus, & Tabs --> <class name="DarkMode::Menu"/> <class name="DarkMode_ImmersiveStart::Menu"/> <!-- Windows 10 Dark Mode > Explorer & Shell --> <class name="DarkMode_Explorer::TreeView"/> <class name="DarkMode::CommandModule"/> <class name="Explorer::CommandModule"/> <class name="DarkMode_Explorer::CommandModule"/> <class name="DarkMode_Explorer::Tooltip"/> <class name="DarkMode::ReadingPane"/> <class name="DarkMode::PreviewPane"/> <class name="DarkMode::ProperTree"/> <class name="ExplorerNavPane"/> <class name="DarkMode::ExplorerNavPane"/> <class name="DarkMode::ItemsView"/> <class name="DarkMode_CFD::Edit"/> <class name="DarkMode_Explorer::Edit"/> <class name="DarkMode_ItemsView::ListView"/> <class name="ExplorerStatusBar"/> <class name="DarkMode::ExplorerStatusBar"/> <class name="DarkMode_InfoPaneToolbar::Toolbar"/> <class name="CommonItemsDialog"/> <class name="DarkMode::CommonItemsDialog"/> </add> <copy> <!-- Windows 10 Dark Mode > Toolbars, Headers, & Rebar --> <properties sourceClass="NavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeNavbarComposited::Rebar" destPart="0" destState="0"/> <properties sourceClass="InactiveNavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeInactiveNavbarComposited::Rebar" destPart="0" destState="0"/> <properties sourceClass="MaxNavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxNavbarComposited::Rebar" destPart="0" destState="0"/> <properties sourceClass="MaxInactiveNavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxInactiveNavbarComposited::Rebar" destPart="0" destState="0"/> <properties sourceClass="Navbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeNavbar::Rebar" destPart="0" destState="0"/> <properties sourceClass="InactiveNavbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeInactiveNavbar::Rebar" destPart="0" destState="0"/> <properties sourceClass="MaxNavbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxNavbar::Rebar" destPart="0" destState="0"/> <properties sourceClass="MaxInactiveNavbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxInactiveNavbar::Rebar" destPart="0" destState="0"/> <properties sourceClass="Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode::Toolbar" destPart="0" destState="0"/> <properties sourceClass="Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode::Toolbar" destPart="1" destState="0"/> <properties sourceClass="Toolbar" sourcePart="2" sourceState="0" destClass="DarkMode::Toolbar" destPart="2" destState="0"/> <properties sourceClass="Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode::Toolbar" destPart="3" destState="0"/> <properties sourceClass="Toolbar" sourcePart="7" sourceState="0" destClass="DarkMode::Toolbar" destPart="7" destState="0"/> <properties sourceClass="ItemsView::Header" sourcePart="0" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="0" destState="0"/> <properties sourceClass="ItemsView::Header" sourcePart="1" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="1" destState="0"/> <properties sourceClass="ItemsView::Header" sourcePart="4" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="4" destState="0"/> <properties sourceClass="ItemsView::Header" sourcePart="5" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="5" destState="0"/> <!-- Windows 10 Dark Mode > Address, Breadcrumb, & Search --> <properties sourceClass="AB::AddressBand" sourcePart="0" sourceState="0" destClass="DarkMode_ABComposited::AddressBand" destPart="0" destState="0"/> <properties sourceClass="AB::AddressBand" sourcePart="1" sourceState="0" destClass="DarkMode_ABComposited::AddressBand" destPart="1" destState="0"/> <properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="0" destState="0"/> <properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="1" destState="0"/> <properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="4" destState="0"/> <properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="5" destState="0"/> <properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="6" destState="0"/> <properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="7" destState="0"/> <properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="8" destState="0"/> <properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="0" destState="0"/> <properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="1" destState="0"/> <properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="4" destState="0"/> <properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="5" destState="0"/> <properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="6" destState="0"/> <properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="7" destState="0"/> <properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="8" destState="0"/> <properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="0" destState="0"/> <properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="1" destState="0"/> <properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="4" destState="0"/> <properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="5" destState="0"/> <properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="6" destState="0"/> <properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="7" destState="0"/> <properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="8" destState="0"/> <properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="0" destState="0"/> <properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="1" destState="0"/> <properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="4" destState="0"/> <properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="5" destState="0"/> <properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="6" destState="0"/> <properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="7" destState="0"/> <properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="8" destState="0"/> <properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_AddressComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_AddressComposited::Edit" destPart="5" destState="0"/> <properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveAddressComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_InactiveAddressComposited::Edit" destPart="5" destState="0"/> <properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxAddressComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_MaxAddressComposited::Edit" destPart="5" destState="0"/> <properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::Edit" destPart="5" destState="0"/> <!--properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="0" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="1" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="3" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="4" destState="0"/> <properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="0" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="1" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="3" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="4" destState="0"/> <properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="0" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="1" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="3" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="4" destState="0"/> <properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="0" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="1" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="3" destState="0"/> <properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="4" destState="0"/--> <properties sourceClass="TryHarder" sourcePart="0" sourceState="0" destClass="DarkMode::TryHarder" destPart="0" destState="0"/> <properties sourceClass="TryHarder" sourcePart="1" sourceState="0" destClass="DarkMode::TryHarder" destPart="1" destState="0"/> <properties sourceClass="TryHarder" sourcePart="1" sourceState="1" destClass="DarkMode::TryHarder" destPart="1" destState="1"/> <properties sourceClass="TryHarder" sourcePart="1" sourceState="2" destClass="DarkMode::TryHarder" destPart="1" destState="2"/> <properties sourceClass="TryHarder" sourcePart="2" sourceState="0" destClass="DarkMode::TryHarder" destPart="2" destState="0"/> <properties sourceClass="SearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_SearchBoxEditComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="InactiveSearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveSearchBoxEditComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="MaxSearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxSearchBoxEditComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="MaxInactiveSearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxEditComposited::Edit" destPart="0" destState="0"/> <properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="0" destState="0"/> <properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="1" destState="0"/> <properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="2" destState="0"/> <properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="3" destState="0"/> <properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="0" destState="0"/> <properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="1" destState="0"/> <properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="2" destState="0"/> <properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="3" destState="0"/> <properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="0" destState="0"/> <properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="1" destState="0"/> <properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="2" destState="0"/> <properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="3" destState="0"/> <properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="0" destState="0"/> <properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="1" destState="0"/> <properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="2" destState="0"/> <properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="3" destState="0"/> <properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode::SearchBox" destPart="0" destState="0"/> <properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode::SearchBox" destPart="1" destState="0"/> <properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode::SearchBox" destPart="2" destState="0"/> <properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode::SearchBox" destPart="3" destState="0"/> <!-- Windows 10 Dark Mode > Buttons, Boxes, & Controls --> <properties sourceClass="Button" sourcePart="1" sourceState="0" destClass="Explorer::Button" destPart="1" destState="0"/> <properties sourceClass="Button" sourcePart="1" sourceState="1" destClass="Explorer::Button" destPart="1" destState="1"/> <properties sourceClass="Button" sourcePart="1" sourceState="2" destClass="Explorer::Button" destPart="1" destState="2"/> <properties sourceClass="Button" sourcePart="1" sourceState="3" destClass="Explorer::Button" destPart="1" destState="3"/> <properties sourceClass="Button" sourcePart="1" sourceState="4" destClass="Explorer::Button" destPart="1" destState="4"/> <properties sourceClass="Button" sourcePart="1" sourceState="5" destClass="Explorer::Button" destPart="1" destState="5"/> <properties sourceClass="Button" sourcePart="1" sourceState="6" destClass="Explorer::Button" destPart="1" destState="6"/> <properties sourceClass="Button" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::Button" destPart="1" destState="0"/> <properties sourceClass="Button" sourcePart="1" sourceState="1" destClass="DarkMode_Explorer::Button" destPart="1" destState="1"/> <properties sourceClass="Button" sourcePart="1" sourceState="2" destClass="DarkMode_Explorer::Button" destPart="1" destState="2"/> <properties sourceClass="Button" sourcePart="1" sourceState="3" destClass="DarkMode_Explorer::Button" destPart="1" destState="3"/> <properties sourceClass="Button" sourcePart="1" sourceState="4" destClass="DarkMode_Explorer::Button" destPart="1" destState="4"/> <properties sourceClass="Button" sourcePart="1" sourceState="5" destClass="DarkMode_Explorer::Button" destPart="1" destState="5"/> <properties sourceClass="Button" sourcePart="1" sourceState="6" destClass="DarkMode_Explorer::Button" destPart="1" destState="6"/> <properties sourceClass="Navigation" sourcePart="1" sourceState="0" destClass="DarkMode::Navigation" destPart="1" destState="0"/> <properties sourceClass="Navigation" sourcePart="2" sourceState="0" destClass="DarkMode::Navigation" destPart="2" destState="0"/> <properties sourceClass="Navigation" sourcePart="3" sourceState="0" destClass="DarkMode::Navigation" destPart="3" destState="0"/> <properties sourceClass="ComboBox" sourcePart="9" sourceState="1" destClass="CFD::Combobox" destPart="9" destState="1"/> <properties sourceClass="ComboBox" sourcePart="9" sourceState="2" destClass="CFD::ComboBox" destPart="9" destState="2"/> <properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="0" destState="0"/> <properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="1" destState="0"/> <properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="4" destState="0"/> <properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="5" destState="0"/> <properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="6" destState="0"/> <properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="7" destState="0"/> <properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="8" destState="0"/> <properties sourceClass="ComboBox" sourcePart="9" sourceState="1" destClass="DarkMode_CFD::ComboBox" destPart="9" destState="1"/> <properties sourceClass="ComboBox" sourcePart="9" sourceState="2" destClass="DarkMode_CFD::ComboBox" destPart="9" destState="2"/> <properties sourceClass="ScrollBar" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="1" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="2" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="2" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="3" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="3" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="4" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="4" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="5" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="5" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="6" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="6" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="7" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="7" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="8" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="8" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="9" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="9" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="10" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="10" destState="0"/> <properties sourceClass="ScrollBar" sourcePart="11" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="11" destState="0"/> <!-- Windows 10 Dark Mode > Lists, Menus, & Tabs --> <properties sourceClass="Menu" sourcePart="9" sourceState="0" destClass="DarkMode::Menu" destPart="9" destState="0"/> <properties sourceClass="Menu" sourcePart="10" sourceState="0" destClass="DarkMode::Menu" destPart="10" destState="0"/> <properties sourceClass="Menu" sourcePart="11" sourceState="0" destClass="DarkMode::Menu" destPart="11" destState="0"/> <properties sourceClass="Menu" sourcePart="12" sourceState="0" destClass="DarkMode::Menu" destPart="12" destState="0"/> <properties sourceClass="Menu" sourcePart="13" sourceState="0" destClass="DarkMode::Menu" destPart="13" destState="0"/> <properties sourceClass="Menu" sourcePart="14" sourceState="0" destClass="DarkMode::Menu" destPart="14" destState="0"/> <properties sourceClass="Menu" sourcePart="14" sourceState="1" destClass="DarkMode::Menu" destPart="14" destState="1"/> <properties sourceClass="Menu" sourcePart="14" sourceState="2" destClass="DarkMode::Menu" destPart="14" destState="2"/> <properties sourceClass="Menu" sourcePart="14" sourceState="3" destClass="DarkMode::Menu" destPart="14" destState="3"/> <properties sourceClass="Menu" sourcePart="14" sourceState="4" destClass="DarkMode::Menu" destPart="14" destState="4"/> <properties sourceClass="Menu" sourcePart="15" sourceState="0" destClass="DarkMode::Menu" destPart="15" destState="0"/> <properties sourceClass="Menu" sourcePart="16" sourceState="0" destClass="DarkMode::Menu" destPart="16" destState="0"/> <properties sourceClass="Menu" sourcePart="17" sourceState="0" destClass="DarkMode::Menu" destPart="17" destState="0"/> <properties sourceClass="Menu" sourcePart="18" sourceState="0" destClass="DarkMode::Menu" destPart="18" destState="0"/> <properties sourceClass="Menu" sourcePart="19" sourceState="0" destClass="DarkMode::Menu" destPart="19" destState="0"/> <properties sourceClass="Menu" sourcePart="20" sourceState="0" destClass="DarkMode::Menu" destPart="20" destState="0"/> <properties sourceClass="ImmersiveStart::Menu" sourcePart="9" sourceState="0" destClass="DarkMode_ImmersiveStart::Menu" destPart="9" destState="0"/> <properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="0" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="0"/> <properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="1" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="1"/> <properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="2" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="2"/> <properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="3" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="3"/> <properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="4" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="4"/> <properties sourceClass="ImmersiveStart::Menu" sourcePart="15" sourceState="0" destClass="DarkMode_ImmersiveStart::Menu" destPart="15" destState="0"/> <!-- Windows 10 Dark Mode > Explorer & Shell --> <properties sourceClass="Explorer::Edit" sourcePart="1" sourceState="1" destClass="DarkMode_Explorer::Edit" destPart="1" destState="1"/> <properties sourceClass="Explorer::Edit" sourcePart="3" sourceState="1" destClass="DarkMode_Explorer::Edit" destPart="3" destState="1"/> <properties sourceClass="Explorer::Edit" sourcePart="1" sourceState="1" destClass="DarkMode_CFD::Edit" destPart="1" destState="1"/> <properties sourceClass="Explorer::Edit" sourcePart="3" sourceState="1" destClass="DarkMode_CFD::Edit" destPart="3" destState="1"/> <properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="DarkMode::ItemsView" destPart="0" destState="0"/> <properties sourceClass="ItemsView" sourcePart="1" sourceState="1" destClass="DarkMode::ItemsView" destPart="1" destState="1"/> <properties sourceClass="ItemsView" sourcePart="1" sourceState="2" destClass="DarkMode::ItemsView" destPart="1" destState="2"/> <properties sourceClass="ItemsView" sourcePart="1" sourceState="1" destClass="DarkMode::ItemsView" destPart="1" destState="3"/> <properties sourceClass="ItemsView" sourcePart="1" sourceState="2" destClass="DarkMode::ItemsView" destPart="1" destState="4"/> <properties sourceClass="ItemsView" sourcePart="2" sourceState="0" destClass="DarkMode::ItemsView" destPart="2" destState="0"/> <properties sourceClass="ItemsView" sourcePart="3" sourceState="1" destClass="DarkMode::ItemsView" destPart="3" destState="1"/> <properties sourceClass="ItemsView" sourcePart="3" sourceState="2" destClass="DarkMode::ItemsView" destPart="3" destState="2"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="1" destClass="DarkMode::ItemsView" destPart="4" destState="1"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="2"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="3" destClass="DarkMode::ItemsView" destPart="4" destState="3"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="4" destClass="DarkMode::ItemsView" destPart="4" destState="4"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="5" destClass="DarkMode::ItemsView" destPart="4" destState="5"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="6" destClass="DarkMode::ItemsView" destPart="4" destState="6"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="7" destClass="DarkMode::ItemsView" destPart="4" destState="7"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="8" destClass="DarkMode::ItemsView" destPart="4" destState="8"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="9" destClass="DarkMode::ItemsView" destPart="4" destState="9"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="10" destClass="DarkMode::ItemsView" destPart="4" destState="10"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="11"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="12"/> <properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="13"/> <properties sourceClass="ItemsView" sourcePart="6" sourceState="1" destClass="DarkMode::ItemsView" destPart="6" destState="1"/> <properties sourceClass="ItemsView" sourcePart="7" sourceState="0" destClass="DarkMode::ItemsView" destPart="7" destState="0"/> <properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="2" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="2"/> <properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="3" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="3"/> <properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="5" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="5"/> <properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="6" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="6"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="1" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="1"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="4" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="4"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="0"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="2" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="2"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="4" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="4"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="6" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="6"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="8" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="8"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="10" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="10"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="11" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="11"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="12" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="12"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="13" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="13"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="14" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="14"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="15" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="15"/> <properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="16" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="16"/> <properties sourceClass="ItemsView::ListView" sourcePart="7" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="7" destState="0"/> <properties sourceClass="ItemsView::ListView" sourcePart="8" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="8" destState="0"/> <properties sourceClass="ItemsView::ListView" sourcePart="9" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="9" destState="0"/> <properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="ExplorerStatusBar" destPart="0" destState="0"/> <properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="DarkMode::ExplorerStatusBar" destPart="0" destState="0"/> <properties sourceClass="Explorer::TreeView" sourcePart="0" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="0" destState="0"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="0"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="1" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="1"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="2" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="2"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="3" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="3"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="4" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="4"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="5" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="5"/> <properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="6" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="6"/> <properties sourceClass="Explorer::TreeView" sourcePart="2" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="2" destState="0"/> <properties sourceClass="Explorer::TreeView" sourcePart="4" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="4" destState="0"/> <!--properties sourceClass="CommandModule" sourcePart="1" sourceState="0" destClass="DarkMode::CommandModule" destPart="1" destState="0"/> <properties sourceClass="CommandModule" sourcePart="2" sourceState="0" destClass="DarkMode::CommandModule" destPart="2" destState="0"/> <properties sourceClass="CommandModule" sourcePart="3" sourceState="0" destClass="DarkMode::CommandModule" destPart="3" destState="0"/> <properties sourceClass="CommandModule" sourcePart="3" sourceState="1" destClass="DarkMode::CommandModule" destPart="3" destState="1"/> <properties sourceClass="CommandModule" sourcePart="3" sourceState="6" destClass="DarkMode::CommandModule" destPart="3" destState="6"/> <properties sourceClass="CommandModule" sourcePart="4" sourceState="0" destClass="DarkMode::CommandModule" destPart="4" destState="0"/> <properties sourceClass="CommandModule" sourcePart="4" sourceState="1" destClass="DarkMode::CommandModule" destPart="4" destState="1"/> <properties sourceClass="CommandModule" sourcePart="4" sourceState="6" destClass="DarkMode::CommandModule" destPart="4" destState="6"/> <properties sourceClass="CommandModule" sourcePart="5" sourceState="0" destClass="DarkMode::CommandModule" destPart="5" destState="0"/> <properties sourceClass="CommandModule" sourcePart="5" sourceState="1" destClass="DarkMode::CommandModule" destPart="5" destState="1"/> <properties sourceClass="CommandModule" sourcePart="5" sourceState="6" destClass="DarkMode::CommandModule" destPart="5" destState="6"/> <properties sourceClass="CommandModule" sourcePart="6" sourceState="0" destClass="DarkMode::CommandModule" destPart="6" destState="0"/> <properties sourceClass="CommandModule" sourcePart="7" sourceState="0" destClass="DarkMode::CommandModule" destPart="7" destState="0"/> <properties sourceClass="CommandModule" sourcePart="10" sourceState="0" destClass="DarkMode::CommandModule" destPart="10" destState="0"/--> <properties sourceClass="CommandModule" sourcePart="2" sourceState="0" destClass="Explorer::CommandModule" destPart="2" destState="0"/> <properties sourceClass="CommandModule" sourcePart="3" sourceState="0" destClass="DarkMode_Explorer::CommandModule" destPart="3" destState="0"/> <properties sourceClass="Tooltip" sourcePart="0" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="0" destState="0"/> <properties sourceClass="Tooltip" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="1" destState="0"/> <properties sourceClass="Tooltip" sourcePart="2" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="2" destState="0"/> <properties sourceClass="Tooltip" sourcePart="3" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="3" destState="0"/> <properties sourceClass="ReadingPane" sourcePart="1" sourceState="0" destClass="DarkMode::ReadingPane" destPart="1" destState="0"/> <properties sourceClass="ReadingPane" sourcePart="2" sourceState="0" destClass="DarkMode::ReadingPane" destPart="2" destState="0"/> <properties sourceClass="PreviewPane" sourcePart="1" sourceState="1" destClass="DarkMode::PreviewPane" destPart="1" destState="1"/> <properties sourceClass="PreviewPane" sourcePart="1" sourceState="2" destClass="DarkMode::PreviewPane" destPart="1" destState="2"/> <properties sourceClass="PreviewPane" sourcePart="3" sourceState="0" destClass="DarkMode::PreviewPane" destPart="3" destState="0"/> <properties sourceClass="PreviewPane" sourcePart="4" sourceState="0" destClass="DarkMode::PreviewPane" destPart="4" destState="0"/> <properties sourceClass="PreviewPane" sourcePart="5" sourceState="0" destClass="DarkMode::PreviewPane" destPart="5" destState="0"/> <properties sourceClass="PreviewPane" sourcePart="6" sourceState="0" destClass="DarkMode::PreviewPane" destPart="6" destState="0"/> <properties sourceClass="PreviewPane" sourcePart="7" sourceState="1" destClass="DarkMode::PreviewPane" destPart="7" destState="1"/> <properties sourceClass="PreviewPane" sourcePart="7" sourceState="2" destClass="DarkMode::PreviewPane" destPart="7" destState="2"/> <properties sourceClass="PreviewPane" sourcePart="8" sourceState="0" destClass="DarkMode::PreviewPane" destPart="8" destState="0"/> <properties sourceClass="PreviewPane" sourcePart="9" sourceState="1" destClass="DarkMode::PreviewPane" destPart="9" destState="1"/> <properties sourceClass="PreviewPane" sourcePart="9" sourceState="2" destClass="DarkMode::PreviewPane" destPart="9" destState="2"/> <properties sourceClass="ProperTree" sourcePart="1" sourceState="1" destClass="DarkMode::ProperTree" destPart="1" destState="1"/> <properties sourceClass="ProperTree" sourcePart="2" sourceState="0" destClass="DarkMode::ProperTree" destPart="2" destState="0"/> <properties sourceClass="ProperTree" sourcePart="3" sourceState="0" destClass="DarkMode::ProperTree" destPart="3" destState="0"/> <properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="ExplorerNavPane" destPart="0" destState="0"/> <properties sourceClass="ProperTree" sourcePart="2" sourceState="0" destClass="ExplorerNavPane" destPart="0" destState="0"/> <properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="DarkMode::ExplorerNavPane" destPart="0" destState="0"/> <properties sourceClass="ProperTree" sourcePart="2" sourceState="0" destClass="DarkMode::ExplorerNavPane" destPart="0" destState="0"/> <properties sourceClass="InfoPaneToolbar::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="0" destState="0"/> <properties sourceClass="InfoPaneToolbar::Toolbar" sourcePart="0" sourceState="4" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="0" destState="4"/> <properties sourceClass="InfoPaneToolbar::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="3" destState="0"/> <properties sourceClass="Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="1" destState="0"/> <properties sourceClass="Toolbar" sourcePart="2" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="2" destState="0"/> <properties sourceClass="Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="3" destState="0"/> <properties sourceClass="Toolbar" sourcePart="7" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="7" destState="0"/> </copy> <add> <property class="DarkModeNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkModeInactiveNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkModeMaxNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkModeMaxInactiveNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkModeNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkModeInactiveNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkModeMaxNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkModeMaxInactiveNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/> <property class="DarkMode_AddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/> <property class="DarkMode_AddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_AddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/> <property class="DarkMode_AddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_Explorer::ScrollBar" part="11" state="0" name="FILLCOLOR:COLOR" value="383838"/> <property class="ScrollBar" part="11" state="0" name="FILLCOLOR:COLOR" value="383838"/> <property class="DarkMode_Explorer::Edit" part="3" state="1" name="BGTYPE:ENUM" value="BORDERFILL"/> <property class="DarkMode_Explorer::Edit" part="3" state="1" name="FILLCOLOR:COLOR" value="212121"/> <property class="DarkMode_CFD::Edit" part="3" state="1" name="BGTYPE:ENUM" value="BORDERFILL"/> <property class="DarkMode_CFD::Edit" part="3" state="1" name="FILLCOLOR:COLOR" value="212121"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="0" name="BGTYPE:ENUM" value="BORDERFILL"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="0" name="BORDERSIZE:INT" value="0"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="0" name="FILLCOLOR:COLOR" value="383838"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="3" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="5" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="6" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="8" name="TEXTCOLOR:COLOR" value="ffffff"/> <property class="CommonItemsDialog" part="1" state="0" name="BGTYPE:ENUM" value="BORDERFILL"/> <property class="CommonItemsDialog" part="1" state="0" name="FILLCOLOR:COLOR" value="f0f0f0"/> <property class="CommonItemsDialog" part="1" state="0" name="BORDERSIZE:INT" value="0"/> <property class="DarkMode::CommonItemsDialog" part="1" state="0" name="BGTYPE:ENUM" value="BORDERFILL"/> <property class="DarkMode::CommonItemsDialog" part="1" state="0" name="FILLCOLOR:COLOR" value="383838"/> <property class="DarkMode::CommonItemsDialog" part="1" state="0" name="BORDERSIZE:INT" value="0"/> </add> <remove> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/> <property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/> <property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/> <property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/> <property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/> </remove> </stylescript>
Windows 10 Dark mode mode Ribbon
By ceo54 in forum Windows 10 Theme Help and SupportReplies: 6Last Post: March 1st, 2021, 05:07 PM -
Windows 10 RS1 SiB Start Menu & Taskbar Style Script and Hack
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 3Last Post: June 1st, 2019, 07:49 AM -
Windows 10 1903 WSB CLASSMAP update and Light Mode Style Script, shellstyle included
By nicely in forum Updates & Style Hacks For WSBReplies: 10Last Post: May 5th, 2019, 06:38 PM -
Windows 10 SiB Start Menu Style Script and Hack
By Mr GRiM in forum Style HacksReplies: 3Last Post: December 24th, 2015, 03:57 PM
Virtual Customs Mobile...
