Results 19 to 20 of 20
December 28th, 2018 04:42 PM #1
- Aug 2011
- Atlanta, Georgia
- 1,574
- 280 Thread(s)
Windows Black Edition for Wimdows 10 1809 and 1903
For Fall 2018 Creators Update 1809 (RS5) only!!
Aero Glass for Win8.1+ V1.5.10
Winaero Tweaker is an all-in-one application which will include most options available in the free Winaero apps and extend it as much as possible. It is a universal tweaker software which supports Windows 7, Windows 8, Windows 8.1 and Windows 10.Recommended Prior to Applying Custom Themes
Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.I take no responsibility for anyone that bricks their system, use custom themes at your own risk!!
Windows 10 Black Edition for 1903 by Mr GRiM Support for Ultimate Desktops 4K 5K 8K
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 30Last Post: February 10th, 2024, 09:03 PM -
7tsp Windows 10 System Icons Black Edition for windows10 1903+
By ArdentAA in forum 7tsp Icon PacksReplies: 0Last Post: September 30th, 2022, 06:55 AM -
Zero-G Special Porters Edition for Windows 10 1903 [19H1] ONLY
By Dark Knight in forum Themes by Dark KnightReplies: 7Last Post: September 11th, 2020, 01:01 AM -
Armoured for Windows 10 1809 and 1903
By Dark Knight in forum Themes by Dark KnightReplies: 4Last Post: May 29th, 2019, 05:30 AM -
Special Edition for Windows 10 1703 - 1809
By Dark Knight in forum Themes by Dark KnightReplies: 15Last Post: February 23rd, 2019, 08:17 PM
