Thread: Aero 7 theme for Windows 10
March 3rd, 2019 03:45 PM #1
Aero 7
Aero 7 Lite
Aero 7 Clear
Aero 7 Square
for full working you need go to
Personalize/Colors and enable Start,taskbar and action center (on)
Aero 7 theme for Windows 10 1903
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 8Last Post: March 1st, 2020, 12:33 PM -
Aero Gray theme for windows 7 by Mr GRIm
By sadiq3210 in forum Theme RequestsReplies: 2Last Post: January 21st, 2019, 04:56 AM -
By Mr GRiM in forum Mr GRiM's Windows 7 ThemesReplies: 19Last Post: August 12th, 2017, 07:41 AM -
Change default Aero theme topic for another installation of Windows 7
By ark22 in forum General Windows 7 CustomizationReplies: 7Last Post: November 29th, 2015, 03:41 PM -
anyone got a aero windows 7 basic theme
By gondudy in forum RequestsReplies: 4Last Post: March 13th, 2013, 07:10 PM
