Results 7 to 11 of 11
March 24th, 2019 04:17 AM #1
- Apr 2013
- New Jesrsey
- 154
- 3 Thread(s)
Windows 10 1903 WSB CLASSMAP update and Light Mode Style Script, shellstyle included
Windows 10 1903 WSB ClassMap update and Light Mode Style Script, with shellstyle included
I Updated classmaps a little bit (Versions Tested 18361-18362)
shellstyle fully updated and not mandatory "yet" to import script to get themes work
Instrucions:
Just replace shellstyle in theme folder.
Open WSB and open the theme with new shellstyle.
Hold shift and click on Import Stylehack and then select "Windows 10 Light Mode"
save and replace theme or rename it to make a backup.
Then you can reopen the saved theme and edit.
using or not the script does not imply the functionality of your themes, its only to show new Windows 10 Light Mode features and only if you use your themes related to Light Mode
I did not put menus and submenus in order 100%
thx Mr GRiM for send me old tool ive lost
If your interested in put categories of the menus and submenus in order i apreciate it. (I do not have much time lately). You can check the script just below:
Code:<!-- Author: Nicely --> <stylescript> <add> <!-- Windows 10 Light Mode --> <class name="FileExplorerBannerContainer"/> <class name="DarkMode::FileExplorerBannerContainer"/> <class name="LightMode_ImmersiveStart::Menu"/> <class name="TaskBand2Light::Taskband2"/> <class name="TaskBand2VerticalLight::Taskband2"/> <class name="TaskBand2SmallIconsLight::Taskband2"/> <class name="TaskBand2SmallIconsVerticalLight::Taskband2"/> <class name="TaskBand2CompositedLight::Taskband2"/> <class name="TaskBand2CompositedSmallIconsLight::Taskband2"/> <class name="TaskBand2CompositedVertical8Light::Taskband2"/> <class name="TaskbandExtendedUILight::TaskbandExtendedUI"/> <class name="TaskBand2CompositedSmallIconsVertical8Light::Taskband2"/> <class name="TaskBarLight::Rebar"/> <class name="TaskBarSmallIconsLight::Rebar"/> <class name="TaskBarLight::Toolbar"/> <class name="TaskBarVertLight::Toolbar"/> <property class="FileExplorerBannerContainer" part="0" state="0" name="FILLCOLOR:COLOR " value="FFF4F4F4"/> <property class="FileExplorerBannerContainer" part="0" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="FileExplorerBannerContainer" part="1" state="1" name="FILLCOLOR:COLOR " value="FFF4F4F4"/> <property class="FileExplorerBannerContainer" part="1" state="1" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="FileExplorerBannerContainer" part="1" state="2" name="FILLCOLOR:COLOR " value="FFF4F4F4"/> <property class="FileExplorerBannerContainer" part="1" state="2" name="TEXTCOLOR:COLOR " value="FFB3B3B3"/> <property class="DarkMode::FileExplorerBannerContainer" part="0" state="0" name="FILLCOLOR:COLOR " value="FF333333"/> <property class="DarkMode::FileExplorerBannerContainer" part="0" state="0" name="TEXTCOLOR:COLOR " value="FFDEDEDE"/> <property class="DarkMode::FileExplorerBannerContainer" part="1" state="1" name="FILLCOLOR:COLOR " value="FF333333"/> <property class="DarkMode::FileExplorerBannerContainer" part="1" state="1" name="TEXTCOLOR:COLOR " value="FFFFFFFF"/> <property class="DarkMode::FileExplorerBannerContainer" part="1" state="2" name="FILLCOLOR:COLOR " value="FF333333"/> <property class="DarkMode::FileExplorerBannerContainer" part="1" state="2" name="TEXTCOLOR:COLOR " value="FF6A6A6A"/> <property class="LightMode_ImmersiveStart::Menu" part="9" state="0" name="FILLCOLOR:COLOR " value="FFEEEEEE"/> <property class="TaskBand2Light::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBand2VerticalLight::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBand2SmallIconsLight::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBand2SmallIconsVerticalLight::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBand2CompositedLight::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBand2CompositedSmallIconsLight::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBand2CompositedVertical8Light::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskbandExtendedUILight::TaskbandExtendedUI" part="0" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBand2CompositedSmallIconsVertical8Light::Taskband2" part="5" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBarLight::Rebar" part="0" state="0" name="TEXTCOLOR:COLOR " value="FF000000"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="TRANSPARENT:BOOL " value="true"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGECOUNT:INT " value="4"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="MINDPI1:INT " value="96"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="MINDPI2:INT " value="120"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="MINDPI3:INT " value="144"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="MINDPI4:INT " value="192"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="MINDPI5:INT " value="240"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="2433:INT " value="288"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="2434:INT " value="384"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGEFILE:FILENAME " value="IMAGE #795"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGEFILE1:FILENAME " value="IMAGE #796"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGEFILE2:FILENAME " value="IMAGE #797"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGEFILE3:FILENAME " value="IMAGE #798"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGEFILE4:FILENAME " value="IMAGE #799"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGEFILE5:FILENAME " value="IMAGE #800"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="3009:FILENAME"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="3010:FILENAME"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="SIZINGMARGINS:MARGINS " value="4, 4, 4, 4"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="CONTENTMARGINS:MARGINS " value="0, 0, 0, 0"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="BGTYPE:ENUM " value="0"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="SIZINGTYPE:ENUM " value="0"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="VALIGN:ENUM " value="0"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="IMAGELAYOUT:ENUM " value="0"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="GLYPHTYPE:ENUM " value="1"/> <property class="TaskBarLight::Rebar" part="4" state="0" name="MAGESELECTTYPE:ENUM " value="2"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="TRANSPARENT:BOOL " value="true"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="IMAGECOUNT:INT " value="3"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="MINDPI1:INT " value="96"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="MINDPI2:INT " value="120"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="MINDPI3:INT " value="144"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="IMAGEFILE:FILENAME " value="IMAGE #795"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="IMAGEFILE1:FILENAME " value="IMAGE #796"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="IMAGEFILE2:FILENAME " value="IMAGE #797"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="IMAGEFILE3:FILENAME " value="IMAGE #798"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="SIZINGMARGINS:MARGINS " value="4, 4, 4, 4"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="CONTENTMARGINS:MARGINS " value="0, 0, 0, 0"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="BGTYPE:ENUM " value="0"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="SIZINGTYPE:ENUM " value="1"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="VALIGN:ENUM " value="0"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="IMAGELAYOUT:ENUM " value="0"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="GLYPHTYPE:ENUM " value="1"/> <property class="TaskBarLight::Rebar" part="5" state="0" name="IMAGESELECTTYPE:ENUM " value="2"/> <property class="TaskBarSmallIconsLight::Rebar" part="0" state="0" name="TEXTCOLOR:COLOR " value="FFFFFFFF"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="TRANSPARENT:BOOL " value="true"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGECOUNT:INT " value="3"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="MINDPI1:INT " value="96"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="MINDPI2:INT " value="120"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="MINDPI3:INT " value="144"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="MINDPI4:INT " value="192"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="MINDPI5:INT " value="240"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="2433:INT " value="288"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="2434:INT " value="384"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGEFILE:FILENAME " value="IMAGE #795"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGEFILE1:FILENAME " value="IMAGE #796"/>"/>"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGEFILE2:FILENAME " value="IMAGE #797"/>"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGEFILE3:FILENAME " value="IMAGE #798"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGEFILE4:FILENAME " value="IMAGE #799"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGEFILE5:FILENAME " value="IMAGE #800"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="3009:FILENAME"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="3010:FILENAME"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="SIZINGMARGINS:MARGINS " value="4, 4, 4, 4"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="CONTENTMARGINS:MARGINS " value="0, 0, 0, 0"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="BGTYPE:ENUM " value="0"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="SIZINGTYPE:ENUM " value="1"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="VALIGN:ENUM " value="0"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGELAYOUT:ENUM " value="0"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="GLYPHTYPE:ENUM " value="1"/> <property class="TaskBarSmallIconsLight::Rebar" part="4" state="0" name="IMAGESELECTTYPE:ENUM " value="2"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="TRANSPARENT:BOOL " value="true"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="IMAGECOUNT:INT " value="3"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="MINDPI1:INT " value="96"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="MINDPI2:INT " value="120"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="MINDPI3:INT " value="144"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="IMAGEFILE:FILENAME " value="IMAGE #795"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="IMAGEFILE1:FILENAME " value="IMAGE #796"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="IMAGEFILE2:FILENAME " value="IMAGE #797"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="IMAGEFILE3:FILENAME " value="IMAGE #798"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="SIZINGMARGINS:MARGINS " value="4, 4, 4, 4"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="CONTENTMARGINS:MARGINS " value="0, 0, 0, 0"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="BGTYPE:ENUM " value="0"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="SIZINGTYPE:ENUM " value="1"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="VALIGN:ENUM " value="0"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="IMAGELAYOUT:ENUM " value="0"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="GLYPHTYPE:ENUM " value="1"/> <property class="TaskBarSmallIconsLight::Rebar" part="5" state="0" name="IMAGESELECTTYPE:ENUM " value="2"/> <property class="TaskBarLight::Toolbar" part="0" state="0" name="TEXTCOLOR:COLOR " value="FFFFFFFF"/> <property class="TaskBarLight::Toolbar" part="1" state="0" name="FILLCOLORHINT:COLOR " value="FFFFFFFF"/> <property class="TaskBarLight::Toolbar" part="2" state="0" name="FILLCOLORHINT:COLOR " value="FFFFFFFF"/>"/> <property class="TaskBarVertLight::Toolbar" part="0" state="0" name="TEXTCOLOR:COLOR " value="FFFFFFFF"/> <property class="TaskBarVertLight::Toolbar" part="1" state="0" name="FILLCOLORHINT:COLOR " value="FFFFFFFF"/> <property class="TaskBarVertLight::Toolbar" part="2" state="0" name="FILLCOLORHINT:COLOR " value="FFFFFFFF"/> </add> </stylescript>
TESTED on manny themes, but I'm not responsible for any system error. Use on your own risk (Also if u gonna edit or test Recommended do it on Virtual Machine)
WSB RS 1903.7z
Last edited by nicely; March 24th, 2019 at 05:03 AM. Reason: forgot to thank some one :)
Nicely
Windows 10 1809 WSB update and Dark Mode Style Script
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 54Last Post: December 5th, 2021, 06:59 PM -
Windows 10 TH2-19h1+ How to change System Glyph Icons Dark and Light mode
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 5Last Post: June 15th, 2020, 02:10 AM -
Windows 10 RS1 SiB Start Menu & Taskbar Style Script and Hack
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 3Last Post: June 1st, 2019, 07:49 AM -
Windows 10 SiB Start Menu Style Script and Hack
By Mr GRiM in forum Style HacksReplies: 3Last Post: December 24th, 2015, 03:57 PM
