Page 1 of 3 123 LastLast
Results 1 to 6 of 13
Thread: Overwatch for Windows 10 RS2- RS5 Share
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ, USA
    31
    1,759
    2 Post(s)
    55 Thread(s)
    Overwatch
    Windows 10 RS2 1703 15063
    Windows 10 RS3 1709 16299
    Windows 10 RS4 1803 17134
    Windows 10 RS5 1809 17763
    Update
    Overwatch RS5 ONLY and Overwatch Dark RS5 ONLY Updated thanks to fixes provided by MR GRiM
    Fixes include
    • White border around navigation bar now removed
    • Slideshow enabled for reduced clutter
    • Theme files merged into a single folder for reduced clutter
    • More backgrounds added
    Update 2
    Overwatch RS2-RS4 and Overwatch Dark RS2-RS4 Updated with fixes provided in the RS5 ONLY versions
    Fixes include
    Uxstyle, [Only registered and activated users can see links. ] and UltraUxThemePatcher[Only registered and activated users can see links. ]UxTheme service hook - Visual Theme Signature Bypass[Only registered and activated users can see links. ]
    Apply
    Install an
    Select the
    Copy a
    Credits for the base theme and go to MR GRiM
    Credits for the icons go to razorsedge and Lamia
    Instructions used in description were copied over from the base theme page posted by Moonique [will still work as there's no difference in the MSSTYLES just different wallpapers basically]
    Download
    Last edited by Nimbi; 5 Days Ago at 09:35 PM. Reason: Fixed some gramatical errors in the description
    Donkuz is offline
    Nov 2017
    Australia
    54
    635
    6 Thread(s)
    Well done Mate, I really like this Dark Glass Theme, thanks for sharing it manCheerz!!
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    23
    2,673
    looks really amaaazing very nice work keep up this good skills and work to the future
    devillnside is offline
    Elite
    Aug 2012
    Dhaka, Bangladesh
    38
    1,149
    12 Thread(s)
    well done nimbi, looks good mate
    Mr GRiM is offline
    Administrator
    41
    5,386
    756 Thread(s)
    Looks good mate, I had a look at them and fixed up a few bits and added the areo peak and show desktop images, also added a few extra wallpapers and combined the dark theme with the normal one to save space.
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ, USA
    31
    1,759
    2 Post(s)
    55 Thread(s)
    Thanks, I'll update the main post as soon as I get this damned slideshow working ....
  1. Overwatch for Windows 7
    By Nimbi in forum Themes for Windows 7
    Last Post: 05-14-2019, 10:44 AM
  2. Overwatch May Be Getting Its Own Breakfast Cereal
    By Feed Monkey in forum Movie News
    Last Post: 10-09-2018, 02:43 AM
  3. Play Overwatch For Free This Weekend
    By Feed Monkey in forum GeForce.com
    Last Post: 05-26-2017, 12:00 PM
  4. Celebrating One Year Of 'Overwatch'
    Last Post: 05-24-2017, 12:00 PM
  5. 'Overwatch' Could Get A Map Editor... Eventually
    Last Post: 03-22-2017, 12:00 PM
